erst engine needed
Old Jan 25, 2010 | 04:20 PM
dazman's Avatar
dazman
Default erst engine needed
Would anyone happen to have or know where i can get a good engine for my 1990 erst, mines popped !,
Old Jan 25, 2010 | 04:26 PM
liam-rst's Avatar
liam-rst
shit happens
orionmojo has 1, link to his post
https://passionford.com/forum/ford-r...ale-loads.html
Old Jan 25, 2010 | 04:31 PM
orionmojo's Avatar
orionmojo
what are you after?
i've got a stripped block, good bores.
a few heads
or a complete engine, ready to run. dropped out of a rotten S2 a fortnight ago.
Old Jan 26, 2010 | 02:39 PM
dazman's Avatar
dazman
cheers guys, basically im the gopher for the mechanic. and aint got a clue with engines, but, he says theres no compression, and the cause is probably fooked pistons, so a block and pistons are needed?? and he can then swap my bits over, it had an upgrade and rebuild before i got it, so dont really know wots up with it till its stripped down, or would you reccomend a full replacement engine? only had the car a month!! gutted......
JoeyBoyden
Jan 4, 2024 02:36 PM
Ellsa
Aug 9, 2015 07:03 PM
col93saphcos
Aug 7, 2015 03:21 PM
