MK3 XR3i 1 owner fsh, proper resto..update 13.5.11
Old Jan 24, 2010 | 09:05 PM
gazm's Avatar
gazm
Smile MK3 XR3i 1 owner fsh, proper resto..update 13.5.11
Hi all gonna start a resto thread here as back in Nov I bought an 83 one owner ,FSH, xr3i thats been garaged for the last 10 years .. still had the 99 tax disc in the window. The plan is a full underbody paint , all running gear re powder coated full body paint , engine strip out etc and rebuild all as standard... - so here goes a few pics of when I picked the car up....
Old Jan 24, 2010 | 09:54 PM
gazm's Avatar
gazm
so i have stripped the car out as per the pics and cleaned the carpet while I had the space ready for whenever i goes back in..... !
Rust by seat anchor hole offside front a little bit in the both footwells also.... but some one somewhere has made a poor repair of the battery tray bulhead area under the dashboard, and theres a shit load of fibreglass filler in there overpaintd black as in the photo, so this will need some attention fore sure.!
So dash etc out and next the loom out ... and followed by the engineand gearbox/.....
so this is where the car is at present, still gotta remove rear running gear and tank etc... but carried on with the engine strip down recently to check shells, crank and bores etc.... more pics up shortly....
Old Jan 25, 2010 | 10:35 AM
gazm's Avatar
gazm
Default few more pics.......
stripped out block etc and the bores are good, shells look in great nick also. pistons rings will need to be replaced , crank looks good too.... seems no frightening things have occurred in there... aprt from the lip on the top of the bores wher the pistons stop short, and also notice the sump return totally blocked up with shite....
ordered new core plugs for the block too.
thats about it for now... thanks
Old Jan 25, 2010 | 10:50 AM
jonny s2's Avatar
jonny s2
love it pal retro cool
Old Jan 26, 2010 | 01:08 PM
stevo123's Avatar
stevo123
The lip on the bores is wear, I would get it re-bored or look out for a newer block perhaps?
Shell looks quite good btw, I hope you get it done just how you want it. Love Mk3's had loads of them, just cant get enough really. I will be watching this one, all the best with the car mate
Old Jan 26, 2010 | 02:14 PM
gazm's Avatar
gazm
thanks mate. hopefully will look well when its done. unsure wether a hone would do it as i need new piston rings anyway....
Old Jan 26, 2010 | 02:29 PM
cossiejsy's Avatar
cossiejsy
very nice project and god luck
Old Jan 26, 2010 | 03:05 PM
drew888's Avatar
drew888
nice looking car, sunburst red bodywork looks in pretty good shape for its age. i wasnt so lucky with mine.
cheers drew
Old Jan 26, 2010 | 04:58 PM
Nice project.Proper retro car.
Old Jan 26, 2010 | 06:28 PM
3dr cossie's Avatar
3dr cossie
looks a good project, keep the updates coming
Old Jan 26, 2010 | 06:31 PM
rs_turbo_tony's Avatar
rs_turbo_tony
looks good mate
Old Jan 26, 2010 | 06:50 PM
mk3_escort's Avatar
mk3_escort
Advanced 5 Door User
Great project, keep the pics coming
Old Jan 26, 2010 | 07:00 PM
Less.'s Avatar
Less.
having a mid life crisis
Makes me me miss my old XR3
Old Jan 26, 2010 | 09:12 PM
gazm's Avatar
gazm
cheers guys... will keep the updates coming ... if anyones tasty with cvh engines can they pop a post up.... need to ask a few questions.... anyway will kick on with it.... thanks for looking
Old Jan 27, 2010 | 10:29 AM
The Youth.'s Avatar
The Youth.
always wanted one of these back in the day but bought an orion ghia I instead, nice to see one going back on the road.
steve
Old Jan 27, 2010 | 12:32 PM
gazm's Avatar
gazm
yep - me too - never had either tho - mate had an xr the same - thought then it was the dogs - well .. it was I suppose ! and my boss at the time had a new orion ghia when new, - as they went like a rocket too.
Old Jan 27, 2010 | 04:17 PM
Good to see it being saved
Old Jan 27, 2010 | 04:19 PM
jdcrst's Avatar
jdcrst
Good work. Another mk3 saved
Old Jan 31, 2010 | 09:36 AM
rs_turbo_tony
wot you need to now about cvh engines mate
Old Jan 31, 2010 | 05:06 PM
marky_g's Avatar
marky_g
Fleet Manager
well done mate
Old Feb 8, 2010 | 12:23 PM
gazm's Avatar
gazm
little update on my engine internals - stripped block back and had the bores measured and theyre .8 tho worn - so will need reboring - but didnt really wanna start buying oversize pistons etc but further more i have removed main bearings and they are 0.4 oversize vandervell - stamped ford - from factory ! so this original block has had the crank ground and oversize bearings fitted at factory , apparently Ford never threw blocks away if they could help it, and re machined wherever they could. so in a quandry as want to keep the orig engine as standard as I could but dont wanna spend on a rebore and pistons etc if I cant source the mains for it...... hmmmm - any ideas ?
Old Feb 8, 2010 | 08:22 PM
rs_turbo_tony
hi mate wot was the problem with engine was it smoking or showing signs of wear e.t.c i would hone block and buy a decent set of mahle piston rings std size 0.8 thou aint alot at all as for shells and bearings use acl duraglide where are you from
Old Feb 8, 2010 | 08:25 PM
TrevCos's Avatar
TrevCos
I absolutely love these. I would love one again for myself, they were the first sporting Ford I owned. Wish I had another garage.
Old Feb 8, 2010 | 08:31 PM
gazm's Avatar
gazm
Hi again mate - no engine has wear as its done 94k , but pretty coked up inside and the oil return was all jammed up - which i guess is pretty normal, only srtipped out due to full resto so wanted to know exactly whats gone on inside the engine, but wanted to try and keep standard if poss on the rebuild therefore keeping the standard pistons etc , but as Ive said the crank is standard but ive got a ford friday afternoon block which by the looks of it theyve overshot their tolerances, so have used o/s shells in the mains. but dont wanna spend big on the internals - escpecially if I cant source 0.4 o/s mains for it.
im in northants mate. duraglide bearings eh ? where from and how much - any idea? and isnt mahle what used to be vandervell ? or are they the one and the same company now.
ta Gaz
Old Feb 8, 2010 | 08:39 PM
Zetecfiesta's Avatar
Zetecfiesta
looks great!
Old Feb 8, 2010 | 09:31 PM
Lee Reynolds's Avatar
Lee Reynolds
Keep the updates coming
Old Feb 8, 2010 | 10:12 PM
gazm's Avatar
gazm
cheers for the comments guys - will keep posting updates etc - gonna get the shell on the spit tommorrow so can kick on with the shell / welding ect. still unsure which ways best with me block tho !
Old Feb 8, 2010 | 10:21 PM
coco16i's Avatar
coco16i
Looks a good one mate and well worth saving.
One of my fav cars i ever owned was a sunburst red A reg XR3i, man i would love to have that car back now
Old Feb 8, 2010 | 10:33 PM
gazm's Avatar
gazm
I bet mate !!
Old Feb 9, 2010 | 06:47 AM
rs_turbo_tony
ta Gaz
0.4 bit strange mate normally 0.5 oversize and up ive got a rs turbo grankshaft but will need regrind should be same crank as for your bores you mite have to go oversize you may be better off taking all components engine ,crank, caps/ half moons to a engine builders or contact jamsport for advise think i would put that engine to one side for now get rest of refurb done and build a zvh on carbs twin 40 s
Old Feb 9, 2010 | 09:05 AM
gazm's Avatar
gazm
Tony - yep gonna leave on the back burner for now - theres a few specialist engine places im gotta speak to as they do and have supplied 0.4 o/s in the past - I dont think its a first tbh as a few places ive spoke to assure me its a fri afternoon job - and back then fords never threw blocks away if they could help - so if the machinist fooked the tolerances up and the casting of the block was good then they just went o/s in the line and sent it out the door !
Anyway will get on with the shell for now.
Old Feb 9, 2010 | 10:22 AM
Rs Adz's Avatar
Rs Adz
looks a nice projecy good luck
Old Feb 9, 2010 | 05:33 PM
rs_turbo_tony
http://cgi.ebay.co.uk/Ford-Escort-Fi...item483813a392
Old Feb 9, 2010 | 05:36 PM
rs_turbo_tony
also this http://cgi.ebay.co.uk/NEW-CVH-ESCORT...item19b94f044c
Old Feb 9, 2010 | 07:17 PM
gazm's Avatar
gazm
thanks for the links mate - had looked at the pistons also,..... spoke to F.W. Thorntons today who have come across this before but had no shells and they put me in touch with a couple of other specialist retro type firms who are getting back to me, although I now have the cross ref part numbers for these shells from AE and vandervell , the shells are .4 oversize on the back, so standard crank.... Ill keep me ears and eyes open, something will turn up.
Old Feb 26, 2010 | 09:18 AM
alk 970's Avatar
alk 970
I have alot of genuine panels left over from failed resoration to fit mk 3 escort would you be interested?
Old Mar 4, 2010 | 10:05 PM
gazm's Avatar
gazm
yep possibly mate - pmed you...
little update few pics below - got the car up in the air and removed the front panel , wings , inner chassis n/s as it was about knackered - so need to source one of these...... also removed inner wings as these need to be replaced... more rot the further I go !!! also bottom of a pillars holed also...
you can see where the rot was behind the chassis leg / bulkhead in the pic... next battery tray / inner wing corner, then iinner / outer sills / floor /boot....
Old Mar 5, 2010 | 06:26 PM
alk 970's Avatar
alk 970
Sorry should have listed the panels i have, they are a pair of inner front wings( 3 bolt strut ealy type), pair of front outer wings, front panel, crossmember and pair of anti rollbar brackets, bulkhead panel, complete scuttle panel, pair of inner and outer a pillar panels and a rear boot floor panel. I hope you find this helpful.
Old Mar 6, 2010 | 09:00 PM
dirtrov's Avatar
dirtrov
nice resto! She's nearly as bad as mine. Enjoy your welding it'll all be worth it. Thats what i keep telling myself!!
Old Mar 6, 2010 | 09:12 PM
Badboybulldog's Avatar
Badboybulldog
looking forward to this one my bro has got a mk3 and he is after some bits if you have any for sale mate
