chargecooler question
i have a pace chargecooler for me series1 that im restoring but would like to know if it would be more efficient if i got a bigger header tank made for it and possibly a bigger rad cheers
In theory yeah it may help drop the water temperatures it a bigger rad was used. Not sure what percentage of gain you would have by increasing. Maybe some of the alloy manufacturers maybe able to help.
If you measure the water temps and the air charge temps, then you will get a good idea as to whether the water is getting too hot to absorb any heat from the inlet air
If the temperatures get close, then you would benefit from more water or a bigger rad
Steven RW from here had a big custom made chargecooler on his S2, he eventually ditched it in favour of a twin cossie setup (lighter and more efficient)
Hope this helps
Neil.
Hope this helps
Neil.
