few cosworth bits more bits added
having a clearout to raise some funds to go towards the mk1 build will add more stuff as i find it
stunning 3 door/2wd tanks most new all powdercoated in candy/chrome red,comes with braided fittings from header tank to turbo/and swirlpot/new bailey mirror image tank/new philloy ps tank/new windscreen washer tank £420 posted SOLD....
...........OR.........
as above with the addition of map sensor bracket/coil bracket/thermostat housing/ign amp plate/power steering pulley/polished lobster back induction pipe/big cone filter with candy red trumpet/newly powdercoated
inlet manifold with new nuts/bolts etc candy fuel rail/fuel pressure bracket/throttle bracket
heater pipe.SOLD..........
NO throttle body and will need a new gasket set(£15) will supply all new nuts bolts for inlet PICS DONT DO THE COLOUR JUSTICE ABSOLUTELY STUNNING.......£525 posted SOLD......................
candy blue fuel rail/thermostat housing/fuel press reg bracket/2wd pulleys £70 ...SOLD.....
brand new nitrous bottle and mount out of the escort huge no fittings £100 posted
sorry for the crap pics
group a coil very little use £15 posted
power steering mount and bracket off my 3 door with all bolts etc £15 posted
twin bar strut brace candy red top plates £80 posted..............SOLD.............
pair of cobra imola 2 bucket seats standard width, with side mounts these are new no wear £260 each to buy without mounts £250 pick up only
unless you arrange courier,will be cleaned dust lol
2wd fuel rails freshly powder coated in siver/candy blue/candy red £20 each posted
race type steering wheel with cosworth boss as new cost£180......£45 posted
tremec/some t5s pro 5.0 quickshift proper bit of kit £55 posted
please check your box this is the short base type not the long base
also have a set of 4 8x17 comp mo,s new style in anthracite with as new nankang ns2,s
totally as new et35 £650 will add pics
carbon timing belt cover new only test fitted £50 posted
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
