stupid pipe question
Old Jan 20, 2010 | 08:38 PM
mike s2 rst's Avatar
mike s2 rst
Default stupid pipe question
i no this is a stupid question and il apologise in advance!!!i stripped my rs engine about 6 months ago and have taken so long to get all the bits and re build it its daft !its all rebuild and went back in last sat and i know where most things go BUT .... i cant remember where two pipes go!On the back of the block where the oil filter screws on there is a plate with two pipes/hoses coming out of the top one long one short but i cant see or find anywhere where they go to???please help!im SOO close to having it running!
Old Jan 20, 2010 | 09:03 PM
Rob_DOHC's Avatar
Rob_DOHC
I think........ but could be wrong, the sandwich plate is water cooled???? so the pipes may link into the cooling system, could also be a take off for gauges etc? I will be under the rs this weekend so if you don't have an answer by then i will let you know, a pic would help..... Rob,
Old Jan 20, 2010 | 10:07 PM
mike s2 rst
yea its the cooler unit that the oil filter bolts to!iv looked everywhere but cant see them!im looking thro past engine build posts but no one takes pics of the back of there block!!(why would they)!
Old Jan 21, 2010 | 09:23 AM
StephenC's Avatar
StephenC
..BS Motorsport..
only picture I can find on here so far
Old Jan 21, 2010 | 03:29 PM
Rob_DOHC's Avatar
Rob_DOHC
rst's dont have a separate oil cooler do they?
Old Jan 21, 2010 | 04:48 PM
Micky's Avatar
Micky
No,its built into where the oil filter screws onto.Regards,Micky
Old Jan 21, 2010 | 08:31 PM
mike s2 rst
StephenC thanks for the pic!!
Old Jan 23, 2010 | 04:45 PM
mike s2 rst
iv spend the day plumbing my engine back in and have everything done and all wired up except one thing : where should the fifth pipe go that comes out of the metering unit?the first four go into the manifold (one per cylinder) but i cant see/find anywhere for the fifth pipe!!would have been running today if not for this pipe!
sorry for the stupid questions but this is my first rst!bought as a non runner and stripped about 6months ago!(partly by someone else)!any help will be gratefully received!!
Old Jan 23, 2010 | 05:00 PM
01dwilkinson's Avatar
01dwilkinson
Mk3 capri 3.0l
Default fuel line
the fifth red pipe is the cold start injector pipe.
look under the middle of the inlet manifold should go into there.
Old Jan 23, 2010 | 06:55 PM
mike s2 rst
i was looking there but ran out of light!il find it tomorrow thanks for the help
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mpilk
Sep 27, 2015 09:21 AM
