Background Removal Tutorial
Old Jan 4, 2005 | 10:39 PM
MadMac's Avatar
MadMac
Default Background Removal Tutorial
Here is our base image
nice, but boring background, just want the car!
So use the background eraser tool set to the following
Now start removing the background, photoshop should pull it out for you automatically
now all the background is removed round the edges, time for a touch up, use the eraser to remove the rest of the background dont worry if you go to far over the car.
Now all the background is removed you need to tidy the edges of the car, select the history brush
and restore the edges of the car you didn't want to remove usually found where similar colours match
now use the eraser again to remove all the left over bit that you dont want and clean the edges up
Hey presto, finished!
Add a new layer behind the carm add a gradient map in layer style, finished
Old Jan 4, 2005 | 10:46 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
More, we want more
Old Jan 4, 2005 | 10:49 PM
benporter's Avatar
benporter
thanx very helpful
Old Jan 4, 2005 | 11:14 PM
frog's Avatar
frog
How's that ???
Although not too sure about the background now, it's the first one I found
Old Jan 4, 2005 | 11:28 PM
frog's Avatar
frog
Hey madmac, without wanting to steal all your secrets, what would you do with the background that appears through a window like below ?
I have removed the grass from around the car, but it still shows in the windows...
Old Jan 5, 2005 | 01:06 AM
MadMac's Avatar
MadMac
its tricky that one, even I haven't managed to figure that out yet, I like the GT40, you managed to keep some of the shadow in it
Old Jan 5, 2005 | 07:15 AM
frog's Avatar
frog
Not too sure how that happened !
I used a smart edge selection tool, then created a mask from the selection, dropped the unnecessary background and added the new background.
I am using paintshop pro 7, which doesn't appear to have the edge eraser tool you mentionned.
Will have to scour the web for tip and tricks on glass by the looks of things.
Old Jan 5, 2005 | 07:49 AM
CosRush's Avatar
CosRush
Nicely done Mac,
Enter the Dragon 'Han' voice says "Your Skills are Extraordinary"
Thanks for the help
Froq,
Ive got PS7 too, and if you select the eraser tool (right click it) then select background tool, at the top of the screen should be a tool bar, where you can select find edges, as Mac has shown above.......
Perhaps you just missed it or the viewing settings are right, dont know for sure but it is on mine.
Old Jan 5, 2005 | 07:55 AM
frog's Avatar
frog
Cool, thanks m8, will have a look.
boeb
Jan 9, 2020 05:11 AM
Orion_Gav
Sep 29, 2015 04:50 PM
