Differance between 4wd and 2wd oil pumps(sorted i think)
Old Jan 4, 2005 | 09:24 PM
seveneigths's Avatar
seveneigths
Default Differance between 4wd and 2wd oil pumps(sorted i think)
Can any one help, what is the differance between them and does anyone
have any pics as i have bought a 200 block long studded built by A1 Rallysport with 900 miles on it.It was out of a 2wd saph and i am fitting it into my 4wd saph and a mate of mine said the pump and pickup pipe are different which i no is correct.The problem i have is my old engine the oil pump and pickup pipe look the same but he just make shore can anyone help.
Cheers Paul
Old Jan 6, 2005 | 11:11 AM
seveneigths
can any one help i dont want to put the engine in the car and find its not the correct pump and cause oil starvasion
Old Jan 6, 2005 | 01:32 PM
Sticky.'s Avatar
Sticky.
Old Jan 6, 2005 | 02:32 PM
wes's Avatar
wes
The pumps are different and so are the oil pickup pipes used in both types, you can bolt either pump to the block, but you must use a 2wd pickup with a 2wd pump and a 4x4 pickup with a 4x4 pump (they aren't physically interchangeable, the feed to the oil spray bar is in different locations on each setup). As to whether you can use a 2wd pump/pickup with a 4x4 sump, i'm not sure on that one, easiest option is to source a 4x4 pump + pickup, job done
Old Jan 6, 2005 | 03:14 PM
seveneigths
Thanks wes i phoned around and pj motorsport told me 4b pumps have 5 nuts on the top and 2wd has 3 nuts that is the only way you can tell when they are fitted.thanks anyway mate
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Dubs44
Aug 21, 2015 02:42 PM
MARKYMARKONE
Aug 20, 2015 12:55 PM
lockie
Jul 31, 2015 10:03 PM
