what power can i get???
anybody got an idea of what sort of power i could get out my rst with a new turbo? and
what turbo should i buy??
here is a list ofspec so far,
+1 accralites, fully balanced bottom end inc clutch and flywheel,
arp rod bolts, uprated bearings, hp oil pump.
head has been mildley ported, althought the inlet manifold is not port matched, and the head poss has oversized valves i did now the size but carnt fin it at the mo.
285tcam, standard pulley and lifters
belived to be a standard turbo but dont know as it came with the car but it was new
k&n cone, pace cooler, grp a coil with motorcraft "7" plugs, superchipped ecu. new dizzy and leads all engine sensors replaced except airflow and emfp. boost is currently set at 14 peak and holds 12.
what power do you think it should have?
what new turbo should i get? and what power may it make then?
thanks for you help
thanks for you help
will efi be decent ish on fuel, 10 years ago my s1 was harsh on fuel, mind I earn double now but have double the out goings
My turbo cabrios pretty standard at the min, and is decent on fuel driven sensibly
But will soon be cossie managed
I should find out soon enough, gotta have it converted before central day at santapod in april, so best get my finger out, starting with fitting the cam kiton friday
Hopefully the last time it will ever run on mfi
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
