escort RST series 2 starting problem
Old Jan 17, 2010 | 08:12 PM
escortturbo's Avatar
escortturbo
Default escort RST series 2 starting problem
My escort RST starts first time even proven in the latest sub zero temps
The issue I have is that after initial start up and running when I switch off it will not start again from warm ,buy it will start again after an hour or so which is keeping me off the road at the moment.
Anyone had the same fault and what was the fix ? appreciate any help.
Allan
Old Jan 17, 2010 | 08:17 PM
gary fraser's Avatar
gary fraser
your starter is right under your turbo and the heat from the turbo heats the starter solenoid thats why it wont start til it cools down, common problem on rs turbos mate try heat wrappin your turbo and downpipe with heat wrap tape. hope this helps mate.
Old Jan 17, 2010 | 08:19 PM
Rob_DOHC's Avatar
Rob_DOHC
yes i have,
but it can be due to a number of reasons, would be handy if you could tell if it wasn't starting due to being too rich or too lean......
Mine was too rich, i measured the water temp sensor (which the simple ecu relies heavily upon) and the car thought it was -15 deg or something lol so was over fueling. This wasn't obvious at start up because the car had a massive air leak as well.
Rob,
Old Jan 17, 2010 | 08:20 PM
Rob_DOHC's Avatar
Rob_DOHC
As above, starter can get cooked, but you will hear it struggle to turn the engine over. Another problem maybe poor compression when warm which is easy to test with a compression tester.
Rob,
Old Jan 19, 2010 | 08:52 PM
escortturbo
Probably not the starter solenoid as the starter turns over the engine no probs,but hanks for the suggestion.
Old Jan 19, 2010 | 08:57 PM
Rob_DOHC's Avatar
Rob_DOHC
Turn the car over, whip a plug out and let us know what you see.
Rob,
Old Jan 19, 2010 | 09:47 PM
alangti's Avatar
alangti
thats exactly what happened to mine the solanoid was knackered heat wrapped the manifold turbo and down pipe and its fine now
Old Jan 24, 2010 | 04:29 PM
TorqueTerrorist's Avatar
TorqueTerrorist
Audi 2.0T FSI
Am i right in thinking that there are cold start valve problems with the Escort Turbo?
Billy_RS
16
Oct 11, 2025 09:41 PM
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 16, 2015 06:38 PM
A.t.p
Aug 15, 2015 11:37 AM
dlwarrior
Aug 5, 2015 10:19 AM
