General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
clean as a baby mate , im liking it , why was it on axle stands ? for a good clean ?
good clean,got the alloy wheels refurbed,new tyres,changed all belts,changed oil for the engine,gearbox and rear diff,done the rear main seal,done the fuel filter got the n/s/f fog light working also done spark plugs
I didnt know people could use the word WANK so much about a set of number plates PMSL , I think they r fine , i dont know what the police will say , cozz i know round my area they are total pigs
hey that is a very nice car,,,, what happened to the saph ?
looks a decent spec 3 door thats for sure !
i melted number 4 piston back in july i think she is just sitting in a lock up at the moment cant bring myself to break her!mind you looking at the way sapps are climbing in price i might wack another bottom end in her
T4 turbo with mar-am 247 shaft AH fabrications intercooler Air injector Wasted spark conversion Closed loop fueling Brand new engine loom Touring car spec head, BD16/14 cams, Blue verniers, isky double valve springs, WRC 4 layer headgasket New 200 block, 6 wrc long studs 4 std head bolts, 7:2-1 compression Mahle pistons ARP rod bolts Fully balanced and lightened bottom end (not too light) 4 paddle clutch Big wing sump Siemens 1000cc injectors L8 ecu with ANTI-LAG and LAUNCH CONTROL Oil cooler Usual chrome tanks under the bonnet Full set of silicone / braided hoses Aeromotive ae1000 fuel pump with -8 to fuel rail and -6 return Aeromotive fuel regulaor Aeromotive high flow fuel filter Glebe straight cut T5 gearbox with non std ratios Quaife atb rear diff R and B rear shims AP 6 pot 330mm front brakes Large rear brakes Fully polybushed AVO coilover suspension Compomotive mo’s 17” 5 spokes in anthracite 3 ford racing gauges Elliot 8k tacho (fitted where std one was)
