FFS!! Just burnt our new carpet! Repair Advice anyone?
Old Jan 17, 2010 | 12:16 PM
MadMac's Avatar
MadMac
Default FFS!! Just burnt our new carpet! Repair Advice anyone?
Seriously I am never doing DIY again, I always manage to make things about 10 times worse
Was using a heat gun to strip some paint off a door frame and I dropped the fucking thing on the carpet long enough for it to melt about 4 square inches off the carpet. Its only been down 4 months
I have plenty of the original off cuts of the carpet to fix it, but anyone got any advice on getting it as seamless as possible?
Old Jan 17, 2010 | 12:19 PM
boothy's Avatar
boothy
Claim on the insurance if you have it ?
Old Jan 17, 2010 | 12:22 PM
RichieST's Avatar
RichieST
When my mum and dad had a new carpet fitted, the room was bigger than the width of the carpet, the fitter kind of melted the sections together so they made a seamless join, was totally un-noticeable. So I should imagine it can be repaired!
Old Jan 17, 2010 | 12:24 PM
longdog's Avatar
longdog
Get a rug. I did the same with an iron years ago, I never did get it looking right.
Hope you have better luck.
boothy's Avatar
boothy
Yep fair enough ,but do you think he could do it without fuckin up the whole room
Old Jan 17, 2010 | 12:26 PM
MadMac's Avatar
MadMac
No I could not
I have had a go at replacing bit of it, one part looks seamless, but the join on one side isn't. Good thing I have plenty of this carpet to butcher to replace it.
Cant put a rug down as its in along the skirting board next to a door that opens outwards.
Old Jan 17, 2010 | 12:27 PM
RichieST's Avatar
RichieST
Nope, hence I mentioned a carpet fitter did it, I suggest he does the same
Old Jan 17, 2010 | 12:32 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Got a picture of the burn mark?
Old Jan 17, 2010 | 12:35 PM
Jessica.'s Avatar
Jessica.
how unfortunate. has the missus seen it yet?
Old Jan 17, 2010 | 12:37 PM
MadMac's Avatar
MadMac
No, ya cnut I have already chopped it out and put it in the bin!
Yes, and she aint happy with me
Old Jan 17, 2010 | 01:02 PM
J98 FYA's Avatar
J98 FYA
as long as the pile is long enough u can get away with removing the section an replacing make sure u get the it the right way round so it goes the same way like the grain of the carpet hard to explain but when u smoove the carpet it ahhhhh bollocks to hard to explain just burn the fucker down lol
Old Jan 17, 2010 | 01:18 PM
Charlie Chalk
Unknown.
Why would you chop it out before you know what you was doing with it LOL
Old Jan 17, 2010 | 01:21 PM
Jessica.'s Avatar
Jessica.
thats mens logic for ya no doubt the missus will make you get a whole new carpet if you dont fix it perfectly
Old Jan 17, 2010 | 01:22 PM
Charlie Chalk
Unknown.
Not mans logic, I'm male.. Stu just lacks common sense I think
Old Jan 17, 2010 | 01:32 PM
slimboyfat's Avatar
slimboyfat
steerfromtherear
Just move some furniture over and tell her in draws the the room looks mutch bigger like that and hope she agrees otherwise ur fukd
Old Jan 17, 2010 | 03:10 PM
matts1's Avatar
matts1
longish pile will mean the fibres around the joins will blend, you need a carpet fitter to sort it really, use proper joing tape that they heat up.
The pile has a direction and so needs to be the right way around, one way brushes the pile up, one way down.
Personally I would make a claim, but if not get the shop that fitted it to send a fitter out Ł20-30 and it should be pretty hard to spot if done well.
Does depend on the carpet though as to the results you will get.
Old Jan 17, 2010 | 03:46 PM
mrjenrst's Avatar
mrjenrst
getting it perfect will be hard tbh, also depends on what shape you cut out.
Old Jan 17, 2010 | 04:15 PM
Charlie Chalk
Unknown.
I wanna see a pic
Old Jan 17, 2010 | 04:28 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
lol at this thread.. i've done the same thing with a heat gun an the misses called me every friggin name you can think of.. 800 quid we paid for it.. luckily the contents insurance sorted it though
Old Jan 17, 2010 | 06:32 PM
foreigneRS's Avatar
foreigneRS
Testing the future
is it like wallpaper or turf where you lay an oversize bit on and then cut through both at the same time to get a perfect join?
Old Jan 17, 2010 | 07:08 PM
matts1's Avatar
matts1
if it is hessian backed then I would cut an exact square from the back using a tempate, then use the same template and cut the back of the carpet.
Then put it in the correct way round (and up lol), but honestly, get a fitter to do it, aint wort the hassle, you may end up with a 6'square after having a go, oops, having a another go, oops
Old Jan 17, 2010 | 07:22 PM
Charlie Chalk
Unknown.
Sounds like he's thrown the template away...
Old Jan 17, 2010 | 07:28 PM
mrjenrst's Avatar
mrjenrst
Sort of yeah, but the main problem is where it is ie main traffic and the bit or shape he's cut out, a picture would make it easyer to laugh at... Sorry i ment see the problem
tankybaby66
Feb 6, 2016 02:24 PM
gambo08
Feb 4, 2016 10:49 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
