turbo BDA epic failure :(now with pics
found this on a south african web site
http://www.fordownerssa.co.za/escort...hp?f=37&t=1755
now thats what i call a total failure the crank is in 5 pieces
have a look at this then
drew's BDA turbo
redracer wrote:This was back in the day, Andrew will have to supply all the details but check that torque of 410Nm
This was my last BDA Turbo engine after 10 yrs of drag racing them.The low graph,221NM 210 HP was with the std BDA camshafts.The second graph (267HP 410NM) was achieved with BD3 cams set at 110 and 114 deg. lobe centers.The boost was set at 1.5 bar(blown through to Dellorto siddies).The car actually started to wheelspin at 410 nm of torque with two adults standing in the boot, the reason for the sudden drop in torque.The car pulled strong up to 8500 rpm and the rev. limiter kicked in at 9000 rpm.Dyno testing was performed at KAR Kempton Park.
1/4 Mile times was constant at 12.7 sec. with street rubber and best 1/4 mile speed of 187 km/h.The reason for changing to the Pinto engine was that the 1600 Kent block (AX P/N) could not handle more power.The last sub. assy destroyed itself by seperating the block in half just above the main bearings, and it destroyed the cross member and steering rack. The cranck ended up in five pieces under the car with all main bearing caps, conrods still attached to pieces of the block.I was a sh#*t expensive failure.$$$$$$$$.It took me 2yrs to build and replace the BDA with the Pinto turbo.
Andrew RWD Shift Stick Driver Posts: 472 Joined: Wed Apr 30, 2008 9:29 am Location: Boksburgi copied this from his thread with a brief description of what happened.
the top end was in a good usable condition but the guy could,nt afford the rebuild so he built a pinto turbo instead it use to live in a mk2 race car the bda made 267hp&410nm of torque.
What did he expect, reving to 9k rpm with a 'rubber' (standard cast) crank, jack shaft and rods (with a bit of stress relieving).
Ford did not put a steel crank,rods, jackshaft in the BDT with four bolt main caps for nothing.
Steve
Steve
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
bigluke200
14
Sep 2, 2015 10:35 PM
