been out for a rip in the beast and it reved out
Old Jan 15, 2010 | 11:46 PM
dale rs1989's Avatar
dale rs1989
Default been out for a rip in the beast and it reved out
just been out in my rs turbo and was ragging it in second and it went right up and past 6000rpm then the car cut out before i could clutch it or take my foot of throttle.it died but i didnt need to start it again it just carried on wat happened ????????????????
Old Jan 15, 2010 | 11:52 PM
Bondy1's Avatar
Bondy1
Hit the rev limiter
Old Jan 16, 2010 | 12:01 AM
dale rs1989
is that all it will be do u thinks ?? its happened on my first fiester and the car went on.i wont sleep untill i no it was nothing lol
Old Jan 16, 2010 | 12:14 AM
ste45's Avatar
ste45
yer a mate of mine s2 used to do this .. was it lyk a missfire wen it hits the limiter?
Old Jan 16, 2010 | 12:17 AM
dale rs1989
yer sort of it just cut out and then i put my foot down and it was ok i think
Old Jan 16, 2010 | 06:45 AM
S1 Combi's Avatar
S1 Combi
Yeah be the limiter mate,my rev counter wasnt workin properly when it went on the rollers and mine did it,runnin up lovely then all of a sudden burr and it died for a few seconds then was fine again
Old Jan 16, 2010 | 11:45 AM
RS1HEN's Avatar
RS1HEN
deffo the rev limit
should be fine
Old Jan 16, 2010 | 12:19 PM
Rob_DOHC's Avatar
Rob_DOHC
i thought you said it needed setting up? and i thought every one told you to go well easy on it until it was set up?
Old Jan 16, 2010 | 04:17 PM
dale rs1989
my friend set it up for me.he said he set the co and wat he could do with wat he had.i want to get it set up proply on rolling road cus it boost well in 1st and 2nd but the boost dont make that much of diff in the rest of the gears i dont no if cus he only set it at 6psi.it goes up to 10 the back down to 6 psi is it ment to do this ?? this is y i think it needs setting up on a rolling road
Old Jan 16, 2010 | 04:29 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it'll be because he can't set up the fuelling on boost without a wideband lambda setup and det detection equipment.
no wonder you didn't feel boost up the gears.
it won't have the same feel in higher gears as the power is more spread out due to gear ratios andthusly won't get through the revs as quickly under throttle.
Mark RS
Mar 5, 2021 06:08 PM
