Diffs and clutch
Old Jan 15, 2010 | 08:02 PM
boost mad's Avatar
boost mad
Default Diffs and clutch
What diffs and clutch would be recomended for a 500-550bhp 4x4 saph ?
Would i get away with an uprated front diff and 2wd rear ?
Old Jan 15, 2010 | 08:23 PM
KSA-Cossie's Avatar
KSA-Cossie
Got quaiffe front (with strenghtening plate) and rear on my saph,not sure what max power they can take though
Old Jan 15, 2010 | 08:34 PM
boost mad's Avatar
boost mad
Is it just the internals you have with the front ? or the casing aswell ?
Old Jan 15, 2010 | 08:38 PM
KSA-Cossie's Avatar
KSA-Cossie
Internals,standard case with the strenghtening plate.
Old Jan 15, 2010 | 08:58 PM
boost mad's Avatar
boost mad
cheers mate
Anyone else ?
Old Jan 16, 2010 | 03:14 PM
ECOS95's Avatar
ECOS95
I'd go for a Quaife Thick wall casing with the strengthening plate & Quaife ATB diff on the front. For the rear I'd use a Quaife ATB in an 2wd casing.
Old Jan 16, 2010 | 03:28 PM
M K's Avatar
M K
gripper plated 7.5" rear diff
quaife thick wall case and atb front diff
this is what wenny used for the last year or so on his mk3 escort 4x4 cossie with hundreds of launches and it proved reliable, although he is lighter than a 4x4 saff remember,
Old Jan 16, 2010 | 04:55 PM
boost mad's Avatar
boost mad
any more for any more ?
Old Jan 17, 2010 | 11:58 PM
M K's Avatar
M K
whats the car used for and how do you drive it?
also what budget you have will be the deciding factor
Old Jan 18, 2010 | 12:14 AM
RWD_cossie_wil's Avatar
RWD_cossie_wil
Clutch you want a tilton twin plate, with a centrepush hydraulic conversion. Rear diff and shafts upgrade to 7.5" 2wd size, with a gripper LSD. Front you want an open diff for the road with a thickwall casing and steel sandwich plate. Gearbox needs to be a Bara straightcut for that sort of power.
Old Jan 18, 2010 | 03:28 PM
boost mad's Avatar
boost mad
it will be mainly a wkend car but will prob see track a few times.
as for how it wil be driven, not 100percent yet as im halfway thro the build. more than likely pretty hard tho.
already got a bara box thanx to YUM.
budget would be as cheap as poss ( i no thats the wrong answer lol) as i want to get it on the road this year. next year will be the saving for better stuff.
at the mo its on standard diffs, front has strengthening plate, but with the current 400bhp its already whining and starting to shit itself.
cheers
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
DavidK
Sep 27, 2015 02:55 PM
