Do i convert to RWD or go 35/65 AWD split ?
right a few of you may know i own a chavyboo Impreza and its gearbox has erm,, well left us pmsl,,,, now the question is do i convert it to RWD or get a DCCD with no electrics and have a rear bias split of AWD 35F/65R ?
this is just a fun toy i will be using for the ring/track and general arsing about in cars with
any ideas ?
DCCD costs more to do as ive gotta by a RA box,,,, im already rebuilding a box to my ratios but this seems a better idea perhaps to do but,,,, well im not sure tbh
just looking for ideas,, i know martin prefers 4x4 but,,,,, well im not sure as i drive like a girl anyway but what should i do
any ideas ?
Why on earth would you want to convert it to RWD? Baring in mind you DON'T like driving cars sideways.
Also worth noting Hayden converted his Scooby BACK to 4WD after doing 3 rear diffs when it was RWD.
im just not sure if i would be better off going RWD and saving the cash im gonna have to spend to get a DCCD as its buying another gearbox just for the rear section as the ratios are WAY too short
at the min im gonna buy a rear diff, would have to buy a RA box for the centre part and then another UK box for the mix ratios as my box is very tall ratio anyway but has short diffs, i dont wanna fit my 5th gear to a RA box and have a change from 4th to 5th feel like im going 3rd to 5th
if i go RWD then all i need is a different rear diff and a UK box for the middle gears but would i then bin it on the bends ?
theres more to RWD than just hanging the arse out,,, theres less transmission losses too and so the taller gears may suit RWD more perhaps
http://www.youtube.com/watch?v=Gkp4mVmZOGY
this is why he done 3 diffs,,,,,, though they are nice wheels i must admit pmsl
) but i wouldnt bother with the electrics as i would have it full front slip all the time hence my thinking of RWD
my box has lost 3rd gear and 4th gear,, basically that shaft might be fooked pmsl and so its being changed, im thinking of a UK spec for the 3.9 ratio on the front,plated front diff fit a dccd rear tail end so to have a 1:1 drop gear and source another 3.9 rear gears and fit to my rear plated diff,,,,,, OR i could get a uk box, weld the centre diff, get the 3.9 rear diff gears and have a box that will do 178mph at 7000rpm instead of 156mph at 7000rpm, being that it would not have 4 wheels to drive makes me think i might require less BHP to get a top speed,, and also save money on fuel too
downside is i might drive it into the armco at the ring pmsl
wouldnt need the diff tbh as im gonna fit a "sport" diff gearing to my plated diff ( thats if it will fit, still in the looking and dreaming stages at the min pmsl)
turbotrev
39
Apr 17, 2016 09:03 PM
