What is the best thing to do to my RST engine
I have a Rst engine from a 92 fiesta, just wondered what was they best route to go to get the most out of it? Is it worth doing a zvh? Sorry to sound silly but a bit new to this.
there is endless things you can do alot of people do the full zetec conversion but a zvh is another cheaper option i suppose and gets good results. personally if id of got my rs turbo that i wanted the zvh route was the way i was going
Depends on your budget and what you want. To be honest I wouldn't bother with ZVH as unless you spend good money on the head teh power vanishes at about 5500rpm. CVH or full Zetec turbo every time.
There is loads you can do with the CVH to make a very quick car
How much you want to spend, and what power you want are the deciding factors in which way to go. Don't forget that the engine build is the cheap bit, it is making the rest of the car good enough to cope with it that is going to cost. Anything over 200Bhp is going to be very expensive if you want it to be reliable, the biggest problem is the gearbox.
Billy_RS
16
Oct 11, 2025 09:41 PM
JoeyBoyden
Jan 4, 2024 02:36 PM
