Removing ABS
Old Jan 15, 2010 | 08:14 AM
Sheldy's Avatar
Sheldy
Default Removing ABS
I am looking to remove the SCS on my S2, does anyone know what's involved and what parts are needed to do the job?
I'm sure I read once ages ago you need to change the master cylinder over to an XR3i item, is that true?
Old Jan 15, 2010 | 09:59 AM
darrenb16two's Avatar
darrenb16two
you need to make a couple of brake lines up but nothing to major mate. You need to change the brake fluid resevoir but cant ever remember changing the master cylinder
Old Jan 15, 2010 | 12:06 PM
mentalasanything's Avatar
mentalasanything
As above really, you just need to make/acquire a pipe from the master cylinder to the T-Pieces on the inner wings and change the fluid reservoir. The only reason you'd need a master cylinder from an XR3i is if it was a non ABS one and you could steal the reservoir.
Lee
Old Jan 18, 2010 | 11:31 AM
Sheldy's Avatar
Sheldy
Is it a worthwhile mod to make or is it better to stick with the SCS system?
The car is mainly going to be used as a track day toy so I'm guessing yes?
Old Jan 18, 2010 | 12:26 PM
Matthew_M's Avatar
Matthew_M
was one of the first mods i did to mine i think it stop much better without it, imo its a shit system anyway, and makes changing the box much easier
Old Jan 18, 2010 | 02:31 PM
mattseries2's Avatar
mattseries2
Definatly worth doing mate, its the best mod to make your brakes better
Old Jan 19, 2010 | 07:17 AM
Sheldy's Avatar
Sheldy
Cool! In that case off it comes! lol
Old Jan 19, 2010 | 07:56 AM
Chris69's Avatar
Chris69
deffo take it off- the standard brakes aren't too bad with it taken off.
specially if going on track its a very worthwhile mod.
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
