converting s2 wheel hubs to studs & nuts
Old Jan 14, 2010 | 11:19 PM
cossie j's Avatar
cossie j
Talking converting s2 wheel hubs to studs & nuts
hi i'm new here need sum info with converting my escort s2 wheel hubs over to studs and nuts is there any thing i can robb parts off ie focus ,late escort,mondeo,fiesta... cheers
Old Jan 15, 2010 | 03:44 PM
xrmalin's Avatar
xrmalin
I just bought some new studs off ebay i think they were only a tenner for the set, i read on here about some one trying to press the studs straight in and it cracked the hud so i drilled mine out a touch and pressed them in.
mark.
Old Jan 15, 2010 | 04:43 PM
RSandy's Avatar
RSandy
yeah my hub cracked due to the bloke not drilling the threads out enough, so make sure u drill out enough clearance and then press, otherwise sourcing a single piece of a single hub is just hassle
Old Jan 15, 2010 | 05:03 PM
Twiddle's Avatar
Twiddle
South lincs rsoc
i just got a hub stud and nut conversion kit of ebay too for extra safety best to thread lock the studs in to the hub.
And before the health and safety officer appears.....
i have done loads of track days with coilovers lots of horses and rose joints race poly bushes and had no problems of any signs of movement stretching or other such nonsense.
Old Jan 15, 2010 | 05:46 PM
Micky's Avatar
Micky
Thats good to hear about them been trackproof!
Any links to who you purchased from??
Micky
Old Jan 15, 2010 | 06:47 PM
Twiddle's Avatar
Twiddle
South lincs rsoc
pretty sure it was this chap
http://stores.shop.ebay.co.uk/Daves-...__W0QQ_armrsZ1
makes wheel changes so much easier
Old Jan 15, 2010 | 08:27 PM
Micky's Avatar
Micky
Thanks Twiddle,I had a look but none for Fords,and a search on ebay turned up none either!
Old Jan 15, 2010 | 08:33 PM
cossie j's Avatar
cossie j
FOUND THIS ON EBAY IF THERE ANY GOOD http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
Old Jan 15, 2010 | 08:36 PM
Twiddle's Avatar
Twiddle
South lincs rsoc
I am sure i asked if they could supply specific length thread and pitch for mine as needed longer than standard fitment stud. I don't think i even said what car it was for, i can't remember the details of measurements tho.
Old Jan 15, 2010 | 08:48 PM
Micky's Avatar
Micky
I think I'll just go down my local Ford dealer and buy 4 studs and 4 alloy wheel nuts (only want 1 per hub,make fitting wheel easier) off a Focus.
Thanks for the help lads,Micky
Old Jan 16, 2010 | 09:05 PM
dobs's Avatar
dobs
im going to order some from here as i only need the studs
goint to be fitting gti wheels
http://www.wheel-nuts.co.uk/product....mm-zinc-plated
Old Jan 17, 2010 | 10:37 AM
marky_g's Avatar
marky_g
Fleet Manager
i drilled all the holes out with 12.5mm drill bit bought new studs from ford (speed shack also sell diff sizes ones) got a steel nut and air gun to pull them through the holes
easy stuff
think you can buy a kit with reverse thread tho so no drilling but its abit dearer
Old Jan 17, 2010 | 12:12 PM
Twiddle's Avatar
Twiddle
South lincs rsoc
Thats what i am using and all ok
Old Jan 17, 2010 | 12:56 PM
10th_racer's Avatar
10th_racer
thats the same way i'v always done them as well.
Old Jan 18, 2010 | 07:02 PM
Micky's Avatar
Micky
Well I purchased 4 wheel studs and 4 wheel nuts at the AutoSport show yesterday,so will get them fitted when the weather warms up.Thanks for the advice lads.Micky
Old Jan 18, 2010 | 07:41 PM
G420 DEL's Avatar
G420 DEL
i went to fords, orderd 16 studs for a escort cossie and put them in no drilling. all ok.. used cossie wheel nuts too (but got them with my cossie wheels when i bought them).
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
hopper350
Sep 4, 2015 12:53 AM
