FAO All Cosworth 2 and 4wd Owners. Great New Products For You!
PassionFords Creator
Hello Everyone,
Most of you will be fully aware of our new range of incredible ultra powerfull magnetic drain plugs.
If not, see here:
We decided that it would be great to develop a magnet that was even stronger than the sump version tested in our videos here: and fit them to bungs in the Cosworths ultra stressed transmission.
Anyone who has had a Cosworth Diff or gearbox apart will know how much swarf these units have inside because sadly they spend most of their life on the edge of failure, they really are a mechanical disaster area and since they have no inbuilt pump and filtration system, let alone regular oil changes, these units can be running on extremely contaminated oil which contributes masively to bearing and gear wear as you will appreciate.
With this in mind, we have 3 new products.
First of all we have a Magnetic Gearbox bung that will fit the MT75 Transmission as fitted to all 4wd Cosworths.
This gearbox has a fill and drain plug that will both benefit from being replaced with these new products.
Price = £17.99 each or £35 per pair.
Secondly we have a magnetic bung that will fit both the fill and drain plugs on the Transfer box fitted to all 4wd Cosworths. This transfer box has a fill and drain plug that will both benefit from being replaced with these new products.
Thirdly we have a magnetic fill plug to fit all 4wd Front Differentials.
Price = £17.99 each.
Finally, we have a magnetic fill plug to fit all 2 and 4wd Rear Differentials.
Please Bear in mind that anyone with uprated boxes and diffs with semi or straught cut gears in them will benefit even more from these products as these products wear out far faster than normal ones.
As an added bonus we have had all the above items manufactured with a 17mm hex head to replace the easily and regularly rounded off allen socket normally fitted.
Anyone interested in purchasing any of these units can simply pay direct to paypal on sales@remapping.co.uk stating in the notes section which product they need. For a limited time these will be postage free.
Thanks for your time guys.
If not, see here:
Here is a great example of why its worth installing one of these:
http://www.minitorque.com/forum/f692/customer-feedback-11652/#post199485
Wilsfoci
15
Mar 30, 2016 10:26 PM
oilman
Trader Parts for Sale.
Aug 30, 2015 08:37 AM
Aug 14, 2015 07:29 AM
