1.8 ZVH piston to cylinder wall clearance
Old Jan 13, 2010 | 04:57 PM
Johnny Knoxville's Avatar
Johnny Knoxville
Default 1.8 ZVH piston to cylinder wall clearance
As above 1.8 ZVH MFI Turbo. What should it be?
Old Jan 13, 2010 | 06:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
it should be whatever the manufacturer of piston states.
what pistons is it using?
Old Jan 13, 2010 | 08:50 PM
Johnny Knoxville
Its standard cast pistons but with adding a turbo i'm sure it will need more clearance?
Old Jan 14, 2010 | 04:49 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
why do you think it will need more clearance?
IMO i don't think they will, no reason for it at all.
Old Jan 14, 2010 | 05:12 PM
Johnny Knoxville
Just the extra heat that the turbo is adding to what was a N/A bottom end
Old Jan 15, 2010 | 09:31 AM
sas's Avatar
sas
should be good!
Yeh, you will need more clearance as you said the pistons run hotter in turbo engine, so require more space to expand. But again the clearance required is dependant on power output required. More power = more heat = more expansion.
If you dont have enuth clearance then the pistons will score the bore, piston crown and skirts
Simon.
TPM961
Jan 15, 2018 10:50 AM
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
IainRS1700T
Sep 25, 2015 06:44 AM
davidfordrs
Sep 21, 2015 04:23 AM
