brakes on s2
Jan 12, 2010 | 07:11 PM
brakes on s2
can any one help!does the hand break light flash when i need to change brakes?while i am driving?
Jan 12, 2010 | 07:15 PM
Jan 12, 2010 | 07:17 PM
don't they av censors on them then?
Jan 12, 2010 | 07:18 PM
its either a bad conectionon handrake switch, or more likley your low on brakefluid which is usually a sighn of rear cylinders leaking a bit.
Jan 12, 2010 | 07:20 PM
do you what brake fluid to use?
Jan 12, 2010 | 07:25 PM
your pads are running low mate
Jan 12, 2010 | 07:39 PM
Jan 12, 2010 | 09:36 PM
If the light comes on when u brake, then your brake fluid is low
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
