Rear disc
Old Jan 10, 2010 | 03:32 PM
mr_joe0606's Avatar
mr_joe0606
Default Rear disc
Hey guys. I have just got a full rear disc conversion. I am just wondering how to fit the rear brake bias it's a willwood item.
CheerS joe
Old Jan 11, 2010 | 06:23 PM
Rick's Avatar
Rick
you need to replumb the brake system. It's currently diagonally split, it needs to be front/rear split to use the bias valve.
Rick.
Old Jan 11, 2010 | 06:51 PM
mr_joe0606's Avatar
mr_joe0606
is This hard work to do. Would it be worth fitting braided hoses throuout.
Cheers joe
Old Jan 12, 2010 | 08:10 AM
mr_joe0606's Avatar
mr_joe0606
I have got 4x4 rear calipers whitch have a larger piston will I need the bias valve.
Cheers joe
Old Jan 12, 2010 | 05:11 PM
martinmilne's Avatar
martinmilne
i got rear disc conversion and cossie discs up front not had it overtake me yet and have slammed the anchors on a few times
Old Jan 12, 2010 | 05:32 PM
mattseries2's Avatar
mattseries2
Its worth fitting it mate as the guys above said your arse could overtake you! I fit one to mine pritty easy to do and like Rick said above u need to re-plub your brakes so they are front and rear. Easy to do mate took me couple hours max to do...if u need any pics etc just ask mate and ill send them to ya!
Old Jan 12, 2010 | 06:02 PM
mr_joe0606's Avatar
mr_joe0606
Cheers people matt where have you fitted the valve and any pics would be great.
Cheers joe
Old Jan 12, 2010 | 06:17 PM
mattseries2
Cheers joe
I made up a metal L shaped bracket and put it down by the handbrake, only trouble with havin it here is u will had to drill 2 holes in your floor.
As u can see thats how to plumb it all in mate, but it would be better if u put bigger brakes on the front then u wont need the bias valve.
And also take out your ABS if u havent already, will make a big difference to braking.
Old Jan 14, 2010 | 06:52 PM
martinmilne
^^^^ have you still got the load compensators ??
Old Jan 14, 2010 | 07:12 PM
mr_joe0606's Avatar
mr_joe0606
What are the load compensators.
Cheers joe
Old Jan 14, 2010 | 10:45 PM
mattseries2
Na mate i took them out, mine were fooked anyway!
Old Jan 14, 2010 | 10:47 PM
mattseries2
Cheers joe
They are the valves that sit near the rear lower arms. Basicly they stop the rear brakes locking up when you go over a bump and the back ends lifts up.
Old Jan 15, 2010 | 05:01 AM
Antti O's Avatar
Antti O
My rear load compensators are fucked too. Rear brakes would not relase completely, approx 10 min after releasing brake pedal brakes are free. So i will throw those away. Can you recommend some good brake bias valve?
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
155lee
Sep 6, 2016 11:10 AM
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
cossirob
Sep 3, 2015 09:17 PM
