Xr2 turbo trackcar brake upgrade!!
Alrite guys,in the middle of rebuilding my xr2 turbo track car for this year.going to be running about 300 bhp so am looking for an all round brake upgrade to fit under 15inch comps.any ideas????someone had posted before saying 4x4 cossie front calipers and mk5 RS2000 discs are a direct fit to front,is this true?? any advice would be great,cheeRS
if i was doing it again for a track car i would go with compbrake complete kit kit up front(750...if you order at autosport might get it cheaper
) and focus st170 rear set up
forget settling for rs2k dics, for about £40 and a little time you can fit 4x4 discs, so up to 280mm discs can be used.
get over to www.xrtwo.com lad on there Fiecos Dan does some conversion brackets for the full setup and will fit under the comps.
jason_nike
Aug 18, 2019 10:53 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Ben26
Aug 27, 2015 08:56 PM
Red_bull
Aug 9, 2015 08:34 AM
