Longer gear ratio
Old Jan 9, 2010 | 10:00 AM
Mr.T's Avatar
Mr.T
Default Longer gear ratio
Well as much as i like driving my little xr2i with 130hp engine i find the gb a bit short at the end. Is there any other gb i can use to make the 5th gear a bit longer? So that i don't have 3k rpm if i drive 120km/h
Old Jan 15, 2010 | 12:55 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
try a diesel gearbox, Im sure they will have a longer 5th gear. may upset your acceleration thoguh with the different ratio's
Old Jan 22, 2010 | 12:39 PM
Mr.T's Avatar
Mr.T
Would think so yes. ANd thats not what i want.
Old Mar 14, 2010 | 06:13 PM
JayCC's Avatar
JayCC
Just fit the 5th gear to your existing box? Although the difference would be slight/fuck all, I would think.
Old Mar 14, 2010 | 08:31 PM
jammerrs's Avatar
jammerrs
id put the dieasel 5th into your box
or if you can find a box with bigger cogs than yours (maybe the mk4 escort 1.4cvh) use 1st to 4th from that then 5th and the final drive from the dieasel.
not sure if that would work or not, just need to find a site that has the ratios on it
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
DavidK
Sep 27, 2015 02:55 PM
