focus headlights
Old Jan 7, 2010 | 09:20 PM
fjc's Avatar
fjc
Default focus headlights
evening all, my focus headlights have stopped working, side lights still work fine and full beam just not main beam.. is there a fuse for them or could it be the switch?? as i cant see the bulbs both blowing at the same time..
cheers
Old Jan 8, 2010 | 06:48 AM
MisiekT_PL's Avatar
MisiekT_PL
why not? if the car is fine, the bulbs can easily blow within minutes/hours of each other. you checked new bulbs? cover he basics first
Old Feb 8, 2010 | 06:30 PM
kevhp171's Avatar
kevhp171
Default mk1 headlights
hiya mate im 99.9% sure it will be the switch itself as this happened to mine a few weeks ago and i checked everything first to find out the switch was faulty in the end you will be able to pick one up from your local scrap yard for a 10er at the most and they are easy to fit
hope this helps
kev
Old Feb 8, 2010 | 07:16 PM
mercury grey minter's Avatar
mercury grey minter
Check the easy things first,fuses and bulb.
Old Feb 8, 2010 | 09:40 PM
MisiekT_PL's Avatar
MisiekT_PL
guys, it was a month ago - guess he'd fix it already
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Mile30
69
May 13, 2017 08:44 PM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
