Crankshaft toothed belt pulley
Old Jan 3, 2005 | 08:47 PM
Filthy Rich's Avatar
Filthy Rich
Default Crankshaft toothed belt pulley
How do you remove this without the special tool ?
If it is indeed possible ??
Thanks in advance
Rich.
Old Jan 3, 2005 | 09:07 PM
Dean Saff's Avatar
Dean Saff
Best off using a puller, there not expensive most part shops sell them,
I tried levering one off before and broke it and they ant cheap.
Old Jan 3, 2005 | 09:14 PM
Filthy Rich
Do you mean the toothed belt pulley or bottom pulley mate?
Bottom pulley is off, want to get to crankshaft oil seal.
There's not enough room to get a puller in at the toothed pulley,book shows a special removal tool.
Thanks.
Old Jan 3, 2005 | 10:57 PM
Dean Saff's Avatar
Dean Saff
Sorry my mistake, never had a problem with mine slid off easy.
maybe soak it in wd40 and try and tapp it with a hide hammer/mallet
Old Jan 3, 2005 | 10:59 PM
Filthy Rich
Been soaked tapped and soaked again
Hopefully it will soak in but i'm not to hopefull
Thanks for the replies tho m8y
jessie_rs
62
Aug 6, 2019 09:27 PM
jonfoc
16
Sep 11, 2018 05:35 PM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
