cosworth ecu connector pin outs?
Old Jan 3, 2005 | 08:11 PM
white cab's Avatar
white cab
Default cosworth ecu connector pin outs?
does anyone have the sensor location into the ecu connection block i have a german wiring diagramme but i am unsure if it is right
thanks to anyone that can help
Old Jan 3, 2005 | 09:45 PM
velocity's Avatar
velocity
that one is correct for a 3 door and some of the pins ar different for the later type ecu's.what one are you looking for, 2wd 4wd,ecos?
Old Jan 3, 2005 | 10:06 PM
white cab's Avatar
white cab
its for 2wd cossie managment conversion the loom i had i bought off spadge it had als wired into it and some of the multi plugs were knackered so i have rebuilt the loom to a better spec with new wires ect
cheeresvelocity,
Old Jan 3, 2005 | 11:23 PM
velocity's Avatar
velocity
you have a pm
j.hammond1
30
Oct 31, 2021 05:28 PM
big_Rad
Sep 15, 2017 09:36 AM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
M K
Aug 12, 2015 06:57 PM
