Steering wheel out of line
Old Jan 6, 2010 | 07:44 PM
PJ_0111's Avatar
PJ_0111
Default Steering wheel out of line
Hi everyone,
I've just joined this forum as I need some help with a problem I've got with my car (Focus 1.8 TDCi).
A couple of nights ago I skid on ice and hit a kerb and my rear offside alloy buckled. I replaced it the next day along with the hub and rear arm but since then when I am driving straight my steering wheel is quite far over to the left. The tracking has been done so it's not that.
Has anyone ever come across this before?
Thanks in advance,
Paul
Old Jan 6, 2010 | 07:52 PM
phil_focus's Avatar
phil_focus
did you just get the tracking done or did you get 4 wheel allignment as the rear end on the focus is adjustable aswell and if you just got the tracking done they wouldnt have addressed the back????
Old Jan 6, 2010 | 07:55 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need all 4 wheels aligned mate, if you change the rear you may have fitted them up wrong so that the rear end isn't the same as it was
all sorts of things to look out for but you won't be able to measure thrust angles and ackerman steering etc at home with a ruler and a bit of string
if you can find a place they normally cost about 350-60 quid for all 4 wheels to be done
make sure you get a print out of what the before/after angles were to be sure things have been done
Old Jan 7, 2010 | 03:56 PM
PJ_0111's Avatar
PJ_0111
I had the wheels aligned aswell. Do you know if their is anyway of adjusting the steering wheel to the correct position?
Old Jan 7, 2010 | 04:08 PM
MisiekT_PL's Avatar
MisiekT_PL
yep - go for allignment again and this time make sure they block the steering wheel in the center position before alligning the wheels
Old Jan 8, 2010 | 10:02 AM
PJ_0111's Avatar
PJ_0111
they blocked the steering wheel aswell, they asked if i was happy with it. everything seemed to be lined up fine on the ramps but as soon as i drove it away it was the same. I took it straight back and he put it the ramps and he said that all 4 wheels were spot on. They checked the arms on the 2 front wheels and they were fine. is it possible that i may have bent the steering column?
Old Jan 8, 2010 | 10:07 AM
stickertone's Avatar
stickertone
it.ll be the tracking still...all 4 wheels may be spot on, but thats with a pissed steering wheel. you want them spot on with a straight steering wheel.
Old Jan 8, 2010 | 02:20 PM
MisiekT_PL's Avatar
MisiekT_PL
PJ - when exactly did they block the steering wheel - before work or during, when the wheels are already on this round plates and can turn easily? they should've done the latter and do it very precisely
Old Feb 11, 2010 | 06:32 AM
melinamotor's Avatar
melinamotor
Farpylee
If the steering wheel has not been secured properly before the alighnment is done some garages have a tendancy to overcorrect one side of the car, usually puts the steering wheel out.
Old Feb 11, 2010 | 01:11 PM
RichieST's Avatar
RichieST
Did you have the tracking done, or proper 4 wheel alignment? (tracking £20-30, 4 wheel alignment, a lot more expensive) They are 2 different things. If you have bent something, then no amount of adjusting the tracking will make it run straight.
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
hopper350
Sep 4, 2015 12:53 AM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
