fiat coupe brembo brake calipers on frst questions?????????
Old Jan 3, 2005 | 03:30 PM
jaypen's Avatar
jaypen
Default fiat coupe brembo brake calipers on frst questions?????????
anyboby fitted or have any advice regarding fitting these calipers to frst or any rs?
i have been told that they are the same as focus rs!!!!!!!!
need to look into getting uprated brakes,stick with esc cos set up or go different route?
if any has seen these calipers they look the bollocks
Old Jan 3, 2005 | 03:43 PM
nthorpey's Avatar
nthorpey
will fit all depending on wheels you want to use. also really need to use custome bells and maximum 315mm rotors for a normal 17" wheel maybe get away with 330mm rotors on a MO type wheel.
Currently working on fitting some RS focus ones to a FRST at the moment, will be abel to help more in the next couple of weeks.
Old Jan 3, 2005 | 03:44 PM
nthorpey's Avatar
nthorpey
Also meant to say that ST170 ones fit on with hardly any work
Old Jan 3, 2005 | 08:44 PM
Dean Saff's Avatar
Dean Saff
I was told there the same calipers as the seat coupra? pug 406? focusRS..
Where you get your calipers from and how much you paid?
yatta
May 21, 2016 10:31 PM
DPDISXR4Ti
Ford Fiesta
Sep 21, 2015 03:51 PM
NC53
Sep 13, 2015 03:05 PM
focus2351
Sep 9, 2015 09:33 PM
cossirob
Sep 3, 2015 09:17 PM
