ecos running 18's what to lower by ??
Old Jan 4, 2010 | 11:22 AM
B1G_RST's Avatar
B1G_RST
Default ecos running 18's what to lower by ??
car is sitting on set of rondel/engles and standard suspention, it looks fine as it sits but dont no if id prefer it with say -20mm ?
any1 got pics of theres down that amount?
been looking at the GAZ coiloverkits on ebay for £500 whitch sounds resonable,
cheers sean
Old Jan 4, 2010 | 11:28 AM
NEIL A's Avatar
NEIL A
There has been a few posts like this in the past think the Ahmed springs gave a good ride quality and height, give Mike at R&B a shout and he will sort you out. If you go for GAZ coilovers get them from Chris ( cossymad ) on here he specs them with a different spring rate that give a better ride.
Old Jan 4, 2010 | 12:28 PM
B1G_RST's Avatar
B1G_RST
cheers neil
Old Jan 4, 2010 | 12:52 PM
ECOS95's Avatar
ECOS95
cheers sean
This is mine on Koni's & Ahmed springs. Got them from Mike R.
You will have to adjust the front spring cups as they foul the front wheels if you have ET18 8.5x18" on 225,40ZR18.
Old Jan 4, 2010 | 01:25 PM
B1G_RST's Avatar
B1G_RST
that looks spot on mate, whats that down ? 20mm? and not being cheeky but what did they set you back ? pm me if preferd cheers
Old Jan 4, 2010 | 01:29 PM
Kelv's Avatar
Kelv
Almost there!
its not so much the '-20mm' drop or whatever the ahmed springs claim to be, dont be fooled into thinking you need a specific drop.
the escos needs to be at a certain height front and rear to enable them to still squat to a slight level, to have the correct roll points to handle correctly, and the ahmed springs achieve this perfectly, matched with a set of Koni's and you will find they will give a much better road feel, overal drive and handling ability than the entry budget level of Gaz coilovers at £500.
but as said, if you do go for Gaz coilovers, order them thru Chris oe Mike as they spec the springs slightly different, Gaz spec them ridiculously hard.
prices here http://www.randbmotorsport.co.uk/shop/Parts.asp?ID=5
now get yourself over to www.escortrscosworth.com
Old Jan 4, 2010 | 01:38 PM
B1G_RST's Avatar
B1G_RST
yeah ino where your coming from mate, i dont want the car too low that it wears the tyres handles terribly and fucks the shafts every few 1000 miles,
im already on escortrscosworth mate,,, im waiting for you to red name me lololol
sean
Old Jan 4, 2010 | 01:49 PM
Kelv's Avatar
Kelv
Almost there!
you should have said Sean, i didnt realise.
unless you have told me and ive just proven how useless i am
Old Jan 4, 2010 | 02:07 PM
ECOS95's Avatar
ECOS95
As Kelv said its aroud 10 to 15mm lower.
I bought them well over a yr ago now, its was under £500 all in from memory but that was a while ago. Well worth doing if your on standard stuff, that and Poly bush the front end.
Old Jan 4, 2010 | 06:54 PM
dakunia's Avatar
dakunia
...and the ahmed springs achieve this perfectly, matched with a set of Koni's and you will find they will give a much better road feel, overal drive and handling...
Hello, are You think about road spec or track spec springs?
cheers
maciek
Old Jan 11, 2010 | 05:42 AM
GML's Avatar
GML
I only think that rear springs are a little bit too hard , but I prefer to have it a little bit hard at the beginning that have eibach -25 wich become -40 for years
gcfcos
88
Sep 15, 2015 03:48 PM
Mk5brown
Sep 9, 2015 12:52 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
hopper350
Sep 4, 2015 12:53 AM
