buying a t3/t4 turbo
hi i want to buy this t3/t4 turbo off turbo revs on ebay and was wondering if it will bolt straight on or will i need some mods. my car has a standard rst turbo on it at the moment. this is the link to the turbo i want to get http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT, thanks craig
buy turbonetics from me. ball bearring, much better, less lag, more power etc...
the one in your link is shitty turbo, china made. this turbo is for a week only. it will dye maybe sooner even.
i'll not comment on quality as i've heard some of these can last a while and some minutes.
what i will say is that it will be very laggy indeed, the compressor housing will foul the erst manifold and so you'll either need a spacer or to shave the manifold and compressor housing with a grinder.
also, you'll need to change the wastegate part of the housing for the rst one as that one in the pic has a saab style flange, unless you get a new down pipe made.
IMO a cossie 2wd/4wd turbo is far more suitable and then use a cossie style flanged down pipe and it'll flow a lot better than the erst one will anyways.
Matt Baxter
Sep 16, 2015 08:30 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
muz
Aug 16, 2015 12:57 PM
