One thing after another!
my S2 is really starting to get me annoyed!!!!
everytime it rains the boot fills up! its wet down the right hand side whats the chances of this been the side glass? it gets wet under the trim below the window that covers the shocker top! then runs down into the spare wheel well as it goes! making my carpet mouldy.
AND it wont bloody dtart when its cold!! odds on its cold atart valve as it winds over and over and wont start untill i push the throttle right to the floor, then when it does fire it runs on 3 for ages till it gets some heat into it-cold start valve?? or yet more other problems??? please help! im considereing getting rid its pissing me off that much!!
mines started leaking aswell resr footwell on passanger side fills up with water and spare wheel well. iv had the drain plugs welded over in footwells thought it was that leaking but........it wasnt! will it be the c pillar???
cheers
cheers
mate mine was getting a mouldy boot carpet and the bottom seal had gone on the drivers rear quarter glass i noticed when there was a few bubbles appearing below the rubber and when i took it out it had a river behind it also had and may sound daft but a split in my rear light gasket replaced them while i was at it and its never done it since
Mark_
40
Oct 2, 2015 04:40 PM
rsguy
44
Sep 29, 2015 03:29 PM
