Anyone need a 4x4 floor pan
The shell has damage to the rear but the floor pan is solid apart from a small section of rust on the tunnel ( easily sorted) the shell will have no doors bonnet or boot, i just thought someone might be doing a conversion and need it ,
The shell is on an L and is just sorn,d at the moment
cheers
cheers
An L reg Sierra is unusual and if I hadn't finished my Sierra last year I would have jumped at it.
Anyone wanting to buy that new XR4i shell that was on ebay recently and treat your L reg as the donor could get a cool car at the end of it.
ummm, you can use 2wd gear on a 4x4 floor pan cant you? save's me cutting up a decent 2wd shell...
would you want the whole shell shifted or could you cut out the floor?
Orion_Gav
Sep 29, 2015 04:50 PM
