engine cutting out
zvh on cossie managment
any ideas,the car revs really good when you give it some , but on idle the revs drop off and cuts out ,its so annoying,then when you turn it over it takes about 10 seconds to fire up,i have checked out some basics any ideas
cheers
cheers
have you had the car running before? or have you just built it up with cossy management? do you have a lambda?
At the moment it sounds as if the fueling needs setting up.
But if it was running fine before i would suspect a sensor,
maybe water or air. etc. Because it runs fine at WOT?
Rob,
Rob,
still no joy, the car will sometimes starts, then you rev it up no problem,then when you take your foot off the peddle the engine revs drop off and its cuts out,then with a bit of luck,then it will fire up again after you keep putting your foot on the throttle for about 10 seconds,could it be the map sensor on the blink giving the wrong singles if so how can you check weather its working or not ,because when you pull the connector off the engine will cut out,its just a thourght, or any other ideas ,good spark,fuel, no air leaks and nothing to do with that cold start valve. cheers ,ray
altering base setting may change the running a little, but there should be a way to set the tps again.
probably best to alter the base throttle position and take it back to where it's been mapped already to get it adjusted accordingly.
help
the car started this morning after about 4 seconds,but it should start as soon as you turn the key, any how it dont seam to run smooth when putting your foot the throttle ,when i took my foot off the throttle the engione revs dropped and the engine cut out and would not start again, what would you try next, cheers
whats happened now is that it will not start,it splutters and farts about but will not have it,good fuel good spark,cannot see any air leaks,remember i am running cossie managment
help
cheers
ray
help
cheers
ray
only thing that makes and engine work is fuel and a spark, it just needs to be in the right order and quantity, best thing to do is get it to a specialist to look at the peramiters on the mapping and set it up again. you may have a duff sensor throwing a bad signal to the ecu, bar spending a lot of cash replacing them all i would get it checked profesionaly.
track.focus'd
Aug 12, 2015 05:53 PM
