What will it take to get 500bhp?
How much money and what will it take to get my escos to 500bhp?
Heres a quick spec now- mongoose exhaust, k&n filter, rs500 intercooler, -31, 3bar map sensor, Grp A cambelt, headgasket and breather, uprated t34 with 360 thrust bearing, msd chip, wasted spark. roughly 380 bhp. turbo is 32psi which im told is max boost. cheers, dave.
engine strip down long stud the block new pistons and rebore l and b the crank and rods new oil pump
wrc hg ported head new inlet cam spacer in the plenum 83 lb injectors gt 30 turbo
new rad new or modded intercooler new hoses clutch??
then box diffs etc etc the above is minimum spec and could go a lot further
id say arount 6k for engine with mapping if you did it yourself or about 10 k for a tuner just the engine spec alone...
cheers
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
10k for a decent transmission set up alone
