problem again
Old Dec 29, 2009 | 04:07 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
Default problem again
hi fellas just a small question about my gear box ,when its cold it doesn't like going into 1st what could this be its the t9 gearbox.
it isn't the fact i have a twincam engine and pinto clutch is it because its been fine its only ever since the cold weather hit
and what whould a quick shift do in my faver?
and i got a problem with mt fuel gauge aswell i got cosworth clocks in my car and when i fill it up it only goes 3/4 of the way full does this happen on replicas
cheers johnandhissaffy
Old Dec 29, 2009 | 04:49 PM
Taps's Avatar
Taps
T9's get like that when its cold, once the oil warms up there then fine again
Old Dec 29, 2009 | 05:03 PM
RichieST's Avatar
RichieST
Thats quite common, its because thebox oil is cold and thick, needs a few miles to warm up. If it is really stiff, press clutch, slot into 2nd then up to 1st, should go in a lot easier.
Rich
Old Dec 30, 2009 | 12:07 AM
johnandhissaffy
Rich
cheers
oh sweet that what iv been doing anyway at the bottom of my road
only thing i was worried about is i fooked another t9 box up something to do with the sincros or something it would only go in 2nd and 4th
what will a quick shift do 4 me ??????
Old Dec 30, 2009 | 02:49 AM
johnandhissaffy
BTTT for the morning people
Old Dec 30, 2009 | 02:54 PM
RichieST's Avatar
RichieST
No a quick shift won't do anything, as that only replaces the gear lever to give you a shorter throw. So if anything, it would make it stiffer.
Old Dec 30, 2009 | 02:59 PM
johnandhissaffy
well that will help coz at the moment its like a prick in a bucket lol
Old Dec 30, 2009 | 03:07 PM
ive got a quick shift fitted to my saff 4+4 and thats the same. Its a right nightmare some times.
Old Dec 30, 2009 | 03:10 PM
utternutter's Avatar
utternutter
isnt it down to the oil??? new mt75 oil normally sorts it
Old Dec 30, 2009 | 03:12 PM
johnandhissaffy
yh tell me about it plus i need to work for my power and changing gear is the only thing slowing me down and my reverse don't really crunch for me so sometimes i don't know if its in 1st or reverse lol
Old Dec 30, 2009 | 03:13 PM
johnandhissaffy
not using mt75 box i have the t9
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
