Intermittent blower P100
Old Dec 29, 2009 | 03:56 PM
mattjwhufc's Avatar
mattjwhufc
Default Intermittent blower P100
Hi All,
I own a Sierra P100, The blower has a mind of its own and when switched on will on only work every now and again for a few seconds at a time. Not great in the frost/snow trying to clear the screen! Does anyone know what the problem might be? I have looked for a Haynes manual for the P100 but struggle to find one that includes the P100 1.8td. Any help would be really much appreciated.
Matt
Old Dec 29, 2009 | 03:59 PM
24vcossiemat's Avatar
24vcossiemat
no more Granada's for me
might be a dodgy switch or lose wire but its quite common on older cars an stuff for the blower motor to have worn bushes. i'd check the switch an wiring first though.. if it turns out the motor has the bushes worn then ya can put new bushes in most of them.. don't quote me on that though, some motors don't come apart, but being that your p100 is older i'd say it can be done easy enough
Old Dec 29, 2009 | 04:02 PM
i would check connections first cause it could be a dodgey connector.
Old Dec 30, 2009 | 06:51 AM
mattjwhufc's Avatar
mattjwhufc
OK, thanks for that. I will check out the connections first. Thanks for your replies. I will have a go when i get in tonight.
Old Dec 30, 2009 | 11:16 AM
I wouldn't worry about a manual that covers the engine you have as the heater fan circuit will be the same across the lot.
I too would be looking for a dodgy connection, leave igntion on, fan on max, and have a good wiggle, you will hopefully soon find it, check the fuse also is securem and not got crap all over it where it contatcs the terminals in the fusebox.
Ian1964
12
Jan 26, 2021 11:57 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
Rammer46
Sep 18, 2015 08:31 AM
Bailes1992
Sep 3, 2015 02:17 PM
