Alternate Car Brands (Non Ford) For ALL cars that are NOT a Ford
1.8td power
Old Dec 29, 2009 | 02:34 AM
taittsierra's Avatar
taittsierra
Default 1.8td power
im new on dis but i just bought myself an 1.8td sierra an i want to make the 1.8td faster or an engine swap.any ideas or advise.an will a diff from a petrol give it more sideways ablity.?thanks in advance.
Old Dec 29, 2009 | 02:35 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
if its sideways you want, you need a limited slip diff or a welded one, changing the ratio wont make a great deal of difference.
Old Dec 29, 2009 | 02:39 AM
taittsierra
but the engine is pretty slow an not anof power to go sideways with a lsd.would a petrol one give more torque?
Old Dec 29, 2009 | 02:41 AM
Chip's Avatar
Chip
If you want a cheap engine thats good for drifting, get a 24V granada lump
Old Dec 29, 2009 | 02:43 AM
taittsierra
wat size engine is it diesel.i was looking for a fast turbo diesel engine just to be diffrent from the rest of the rwd's about my town.
Old Dec 29, 2009 | 02:53 AM
taittsierra
i was thinking of a 2.5td omega engine does anybody no if this would be a tricky engine swap?
Old Dec 29, 2009 | 08:34 AM
combivan's Avatar
combivan
the 24v is the way to go put one in my capri with 100 shot of nos free flow exhaust all i did with the engine was change the oil regular made 217 bhp standard 332 with the nos and anough tourqe to blow a set of new tyres in afternoon of fun. still going three years on.
if you get the doner car its all a straight swap
Old Dec 29, 2009 | 08:46 AM
jghs83's Avatar
jghs83
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
free upgrade with a good set of tools, i know this wont give a massive hike in power but try turning the turbo up by winding the actuator rod in by 360 degrees and turn up the boost fueling on the pump
Old Dec 29, 2009 | 09:07 AM
Chip's Avatar
Chip
No its not an easy conversion really, why not just drift the omega instead if you want a better engine?
Old Dec 29, 2009 | 08:11 PM
bortaf's Avatar
bortaf
You can tweak the pump mixture and up the boost a wee bit, have a look through a mondeo forum the Mk1s use the same engine so mods are very similar
A nice exhast will make a bit of differance, check out the sierra owners club forum, a member on ther has a tweaked turbo diesel saph
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
