mk1 escort cosworth project the build begins pg6
Old Dec 28, 2009 | 07:53 PM
cossytonyt's Avatar
cossytonyt
Default mk1 escort cosworth project the build begins pg6
some of you may have seen this on here for sale a while back all built ready for cosworth!!!
oh well after a lot more work then maybe lol,its had a shed load of money thrown at it well up to the engine bay anyway,after some head scratching knowing things were not right apart from the obvious brakelines and fuel pressure reg mounted on the hotside
and a visit from mel it seems that the tunnel is wrong,gear lever hole wrong, box mounted to far forward, lol and some repairs needed to front chassis legs,apart from that it should be a straight forward conversion.
had a few of these but none with a rear set up like this one will launch mint on the strip but dont know what it will be like on the roads,should be fun it has a full ladderbar set up
with in board strange coilovers and a 9" mustang axle with a locker diff,full cage etc
heres a few pics for now will set about cutting off the engine cradle tommorra as the captive nuts have sheared
the engine thats going in just stage 3 for now
Old Dec 28, 2009 | 08:23 PM
cossiejsy's Avatar
cossiejsy
Very nice and motor looks very nice mate
Old Dec 28, 2009 | 08:29 PM
carlos1395's Avatar
carlos1395
hi tony its carl marks mate
very nice mk1 i think ive seen that car before did you have any look with the front brakes for the saff
Old Dec 28, 2009 | 08:31 PM
COLEYST200's Avatar
COLEYST200
i love mk1 escort's and yours is one of them now but get rid of the crank pulley it lets the motor down big time but very nice
Old Dec 28, 2009 | 08:53 PM
cossytonyt's Avatar
cossytonyt
lol mate didnt realise got all new pulleys just havent got round to putting them on does look shit thou lol.
carl will sort them out for you bud was talking to mark said you were having change of plans
Old Dec 28, 2009 | 09:16 PM
COLEYST200's Avatar
COLEYST200
is this ment for me as iv been getting some parts of mark for my car
Old Dec 28, 2009 | 09:23 PM
liam-rst's Avatar
liam-rst
shit happens
thats the fuckin tits
Old Dec 28, 2009 | 09:59 PM
cossytonyt's Avatar
cossytonyt
no mate
Old Dec 29, 2009 | 07:05 PM
cossytonyt's Avatar
cossytonyt
got a bit more done on the mk1 today fitted some aero catches on the bonnet
while i got my head around chopping some holes in the chassis to get to the captive nuts
then trial fitted the new wcxm to the engine,was expecting to have to trim it back to clear the sump as i want to keep the standard 2wd item and not go the rs2000 route
found ive got about 10mm gap so im hoping it will be alright ?
next pics show the repairs needed on the chassis leg where the wcxm mounts
cut a inch slit both ds and ps to get into the captive nuts
the problem lol
last lot show the problem with the box about 2 inch to far forward also the brake
lines and fuel line on the hot side
and finally all the stuts,t5,& old xmember stripped out and the new wcxm fitted
test fitting the engine tommorrow and will repostion the box etc
Old Dec 29, 2009 | 08:19 PM
melspec1's Avatar
melspec1
Yo mate, the wcxm looks a nice fit on there, AND YOU NEED TO LOSE THAT BRAKE PIPE SET UP!....... while you at it, you mite as well take that fuel pipe out the way as its going to be on the other side plus inside the car! Plus as well mate the wcxm bolts mount will be getting tube mounted to the chassis remmber......
Top work tony mate...]
Old Dec 29, 2009 | 08:50 PM
steve st220's Avatar
steve st220
"SNIFF MY DIFF"
looks a realy good project, shame about all that extra work you got to sort out.
Old Dec 29, 2009 | 08:56 PM
melspec1's Avatar
melspec1
Tony love that extra work on his hands, he just can not help him self!:gr in:
graham c's Avatar
graham c
hi mate have you just bought this car
Old Dec 29, 2009 | 11:05 PM
cossytonyt's Avatar
cossytonyt
i,ll just sort out the straight forward stuff leave all the complicated bits and fab to you lol
graham c, yes mate few weeks back,good start just needs a bit fettle here and there
Old Dec 29, 2009 | 11:12 PM
melspec1's Avatar
melspec1
I must say mate your doing realy well....
its going to be another Mk1 escort in the NORTHEAST to kick ass...
Old Dec 29, 2009 | 11:18 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
that looks VERY nice
Old Dec 30, 2009 | 06:01 PM
cossytonyt's Avatar
cossytonyt
done a bit more today stripped the rest of the bay brakelines/fuel etc modded
the lip on the bulk head.
then dropped the engine in for a test fit
happy with the position, height etc plenty of clearance front and back
so tommorra gonna get the box mounted and re do the gear lever appature
then can strip it all out ready for mel to seam weld and gusset the bay
Old Dec 30, 2009 | 06:14 PM
melspec1's Avatar
melspec1
ive sent you a pm
Old Dec 30, 2009 | 06:17 PM
melspec1's Avatar
melspec1
Spot on tony mate, you doing realy well!
nice job on the bulkhead seam lip...
Plus that motor realy sitting nice in the bay!
TOP JOB!
Old Dec 30, 2009 | 06:20 PM
cossytonyt's Avatar
cossytonyt
cheers bud,seemed plenty of room even with the manifolds on,will be fun tommorra
me trying to squeeze under the car with the box lol "new years res DIET"
moved the seat down and back as well seems a bit better still need greasing to get in thou lol
Old Dec 30, 2009 | 08:20 PM
turnover's Avatar
turnover
stop eating all the pies you fat f**cker lol ,looking good mate keep it up,and Mell its about time yours was finished
Old Dec 30, 2009 | 08:38 PM
melspec1's Avatar
melspec1
YEAH!... yes it be finish't when i stop working on other cars.....
Old Dec 30, 2009 | 08:58 PM
royRS's Avatar
royRS
Default escort
realy nice car!
wich propshaft do u use?
do you know if the std rs2000 one fot into an T5 box?
graham c's Avatar
graham c
think this is the same colour as mine come to think of it
Old Dec 30, 2009 | 09:00 PM
graham c's Avatar
graham c
yes it dose but think you need inch taling off it. it a bit since i did mine
Old Dec 30, 2009 | 09:02 PM
COLEYST200's Avatar
COLEYST200
the motor look nice in there mate
Old Dec 30, 2009 | 09:48 PM
cossytonyt's Avatar
cossytonyt
cheers mate can you pm me where to get some of them pulleys you put on your 3 door?
Old Dec 30, 2009 | 09:51 PM
cossytonyt's Avatar
cossytonyt
"ITS ME GLANDS" lol
Old Dec 30, 2009 | 10:00 PM
dingla rs's Avatar
dingla rs
looks a similer garage to graham
Old Dec 31, 2009 | 06:27 PM
melspec1's Avatar
melspec1
"ITS ME GLANDS" lol
DUDE! dont lie!
you said to me the other day'' saying you taking shape to be in the new film 'HULK 3' ..............
Old Dec 31, 2009 | 07:23 PM
Captain500rs's Avatar
Captain500rs
Fook me aint you been busy lol, can guarantee it will get built and sold,if it gets that far lol
The hulk ?? He told me, he is the new face of weight watchers
Old Jan 1, 2010 | 02:43 PM
cossytonyt's Avatar
cossytonyt
lol just naturally big boned lol
Old Jan 4, 2010 | 06:26 PM
cossytonyt's Avatar
cossytonyt
not done much to cold lol been messing about with wheel sizes here a few pics with 9x15s on the rear with 225/50/15s what do you think could possibly fit 10s with slight modifications opinions????????
Old Jan 4, 2010 | 07:33 PM
andy escos's Avatar
andy escos
looking real good love the wheels
Old Jan 4, 2010 | 07:48 PM
Mr RS500's Avatar
Mr RS500
Come on Tony get ya finger out
Great project
Old Jan 4, 2010 | 08:14 PM
graham c's Avatar
graham c
wot brakes you using under them wheels, you can get 2wd front cossie ones to fit easy
Old Jan 4, 2010 | 09:58 PM
turnover's Avatar
turnover
its got cossie rear brakes mate,and i thought you wanted to be the new giant haystacks tony lol
Old Jan 5, 2010 | 04:55 PM
graham c's Avatar
graham c
wot brakes are on the front tho?
Old Jan 5, 2010 | 06:42 PM
cossytonyt's Avatar
cossytonyt
am after a set for the front mate not sure what way to go with them yet,what you running on yours ?
Old Jan 5, 2010 | 07:20 PM
graham c's Avatar
graham c
the one in my sig woz 2wd and ran saff cossie 2wd 4 pots cheap to get hold of and not bad to fit ?285 disc! the one am building now is 4x4 ? give me a shout if you go 2wd 4 pots will get pics up of bracket
