wiper relay
Old Dec 26, 2009 | 06:36 PM
cossiejay's Avatar
cossiejay
Default wiper relay
can anyone please tell me where the wiper relay is on my sapphire i know it is in the fuse box but dont know which one my wipers have stoped returning to the bottom when turned off and the intermitent no longer works at all
Old Dec 27, 2009 | 02:09 PM
Yes just look for one that has wisch interval steurgerat on it, all the wiper functions, even on go through the unit, which is the timer.
These can be modded by fitment of an alternative that wipes for 4-5 wipes after the wash is operated, ie so you just press wash and it does the wipers for you.
Old Dec 27, 2009 | 03:13 PM
cossiejay's Avatar
cossiejay
cheers i have found it a big red one will get a new one tomorrow and try it hopfully it will be that as i have cleaned all the earths just in case
Old Dec 31, 2009 | 06:00 PM
cossiejay's Avatar
cossiejay
got new relay no change has anyone any ideas
Old Dec 31, 2009 | 06:49 PM
jon@work's Avatar
jon@work
have you checked fuse 22 ?
Old Dec 31, 2009 | 06:52 PM
cossiejay's Avatar
cossiejay
yes they work perfect but when i turn them off they stop where they are and dont return to the bottom of the screen so far i have changed the relay for a new one,wiper motor,fuses,and cleaned the earths they where perfect until the snow came
Old Dec 31, 2009 | 07:10 PM
jon@work's Avatar
jon@work
have you checked fuse 15 ?
Old Jan 2, 2010 | 01:05 PM
If they stop where they are, check for the permanent live supply at the connector on the wiper motor, this is what supplies current after switch off.
If that is ok take apart the wiper mech on the motor, you will see a nylon wheel about 32 in diametre that turns with the arm, this has a dip in it where the switch rests when stopped(it cuts the circuit), check the wires have not broken on this.
This will be found behind the cover that is attached with rivetts, just use tie wraps afterwards with sealant around the edges to seal.
Old Jan 2, 2010 | 01:13 PM
mechanic28's Avatar
mechanic28
sounds like your wiper motor is getting tired
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
stevecfrst1
Sep 30, 2015 05:18 AM
SMILER258
Sep 28, 2015 09:04 AM
IainRS1700T
Sep 25, 2015 06:44 AM
