-31 actuator
Old Jan 2, 2005 | 03:47 PM
jasonrallying's Avatar
jasonrallying
Default -31 actuator
can anyone tell me the best way to set up a -31 actuator
car seems to be overboosting. how much thread should
be visable thanks.
Old Jan 2, 2005 | 05:27 PM
TIFF's Avatar
TIFF
Chasing Radders
It depends on SO many things mate
What Turbo
What injectors
What intercooler etc
etc
etc
Get it to a reputable tuner mate, not worth the cost of an engine build
Old Jan 2, 2005 | 07:35 PM
jasonrallying
Default actuator
thanks mate but car is completely standard 204 bhp model.
lever broke on waistgate so had to take off to be welded,
now not sure how long actuator arm should be.
Old Jan 16, 2005 | 12:47 PM
Stu @ M Developments's Avatar
PassionFords Creator
3mm preload is std. so 3mm too short to just "slot over" the pin.
Old Jan 16, 2005 | 02:52 PM
robrs2's Avatar
robrs2
Got told by a local turbo agent that it was 5mm preload ? did they give me the right number ? I've set mine to 5mm But aint run it yet.
Old Jan 17, 2005 | 01:27 PM
3mm is the correct base setting and also the minimum that should EVER be used. This will likely require shortening unless actuator and amal valve are brand new.
Old Jan 17, 2005 | 01:52 PM
jasonrallying
Default thanks stu.
thanks mate tried that now seems about right.
Old Jan 18, 2005 | 08:29 AM
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
