Engine help
Old Dec 25, 2009 | 04:58 PM
acecraig's Avatar
acecraig
craig89
Default Engine help
hi i have a peugeot 205 with a 1.9 mi16 conversion
since i got it the running temp has always been realy low but recently it has started to splutter about the 3500k mark in every gear part from first
was like overfueling. i put a thermistat in it because There was not 1 in it. and now it runs realy well when cold and mid temprature but when it gets hot it starts to lose oil pressure then were back to spluttering and chuging again checked the oil in it there is plenty but it is as thin as water so ive got some 15w40 there so im gona put that in it tomorow to see if it will hold oil pressure when hot.
if it is not that does any1 have any other suggestions as to what it could be any ideas would be good
cheers craig
Old Dec 26, 2009 | 02:43 PM
acecraig's Avatar
acecraig
craig89
ok so i put fresh oil in it today seems to be holding oil pressure better than b4 but is still loosing pressure when it gets to running temp
so now im thinking oil pump. i am not sure if it has a pressure release valve that could be sticking open. just an idea. anybody else?
Old Dec 26, 2009 | 02:58 PM
acecraig's Avatar
acecraig
craig89
i have seen this what do u think would it help
hopper350
Sep 4, 2015 12:53 AM
Sep 3, 2015 10:49 AM
