best focus manifold option
Old Dec 20, 2009 | 05:11 PM
matt24680's Avatar
matt24680
Default best focus manifold option
hi there i was wandering what is the best manifold option for my 1.8 zetec focus i dont want a de cat but can i get a performance amnifold and just use the oringinal cat or would that be too restrictive??would a blacktop 2.0 focus manifold work and i could just bolt on the cat i have??
Old Dec 20, 2009 | 05:32 PM
matt1.8z's Avatar
matt1.8z
2.0L manifold is same as the 1.8
get a st170 manifold and cat and flexi best manifold and bolt on mod u can do ull need the st dipstick and think with some cars the powersteerin pipe as well
matt
Old Dec 20, 2009 | 05:53 PM
JackCornick's Avatar
JackCornick
I wouldn't have thought replacing it with a Ford mani would really be that beneficial for the £££. The standard RS mani and cat are horribly restrictive!
Id say the performance 4-2-1's would only really be worth it...
Old Dec 20, 2009 | 06:10 PM
jammerrs's Avatar
jammerrs
st170 manifold mate
lots of people uprate to these as they are tubular and not cast like the other ones are
Old Dec 20, 2009 | 06:29 PM
matt1.8z's Avatar
matt1.8z
st170 manifold is a 4-2-1 mate and lets him have a cat with out custome weldin one in to the system and i have heard with the st170 manifold and cat u gain 10bhp+
matt
Old Dec 23, 2009 | 10:23 AM
woolford's Avatar
woolford
Hi.
I have an st170 manifold on my focus but no cat or silencers etc i had it altered so it woud bolt straight on to a normal exhaust pip fitting not the 3bolt thing it comes with.. and also got a custom power steering pipe.
Paul
Old Dec 29, 2009 | 08:01 PM
matt24680's Avatar
matt24680
hi there i thinki i will get a st170 manifold but i was wandering is the lambda sensor the same as the one on a ford focus 1.8 zetec or if it comes with it will the other end fit in ok??also will i need a powersteering pipe and st dipstck as said above??
thanks
Old Dec 29, 2009 | 09:11 PM
woolford's Avatar
woolford
Yes the lambda will fit but if you get decat there is another sensor needed for that. neither the 1.8 2.0 has so you will need a piece making to fit. Also u will defo need dipstick and pipe
Old Dec 29, 2009 | 10:13 PM
matt24680's Avatar
matt24680
hi there thanks for the reply what powersteering pipe do i need ???also would i need the st170 dipstick pipe as well??the lambda thing seems pretty confusing to me what are the chances of it having decay is this decay on the sensor bit itself??
thanks
Old Dec 29, 2009 | 10:45 PM
woolford's Avatar
woolford
Sorry spellin was pooh read last post again. If you get a little pipe made to replace the cat you only need ur lambda. U need both dipstick and powersteering pipe from st170. I had a hydraulic pipe made.
Old Dec 30, 2009 | 09:21 AM
matt24680's Avatar
matt24680
hi there thanks for explaining it more i amnt planning to replace the cat so will the lambda sensor be ok also do i need a st170 diptick tube??or will my 1.8 tube hold the dipstick?
thanks
Old Dec 30, 2009 | 09:25 AM
hatton89's Avatar
hatton89
Shawspeed zs
the cat is on the down pipe aint they?
Old Dec 30, 2009 | 10:11 AM
hineho87's Avatar
hineho87
I swapped my manifold for the st170 one on my 1.8. I have a guide somewhere if any1 wants it.
On mine all i had do woz move one of the lamba sensors on the cat as it was close to driveshafts (or woz close to somethin else). I then needed extend the wires on my existing lamba sensor.
I also bought the st170 dipstick tube (£10 from ford, you can bend ur existing one but it aint worth it. I also painted the tube in high temp paint as well) and used my existing dipstick. I didnt bother with st170 PS pipe or aftermarket one, i just rotated the bit of pipe from side of manifold round to front of engine bay and iv ad no problems (touch wood lol).
Iv noticed an improvement in accelaration and exhaust tone (seems more raspy now)
Basically parts from st170 you need are:
Manifold
Cat (or decat) and flexi pipe
Gaskets
Oil dipstick tube
PS Pipe (if you want it - costs bout £80/£90 from ford)
If using cat on a 1.8, you need a bolt for blankin off lamba sensor and then the bit where lamba sensors goes from another cat to fit on ur st170 one (sorry couldnt think of its name lol)
Jus let me no if u want the guide
Matt
Old Dec 30, 2009 | 10:12 AM
hineho87's Avatar
hineho87
the cat is seperate on the st170
Old Dec 30, 2009 | 10:46 AM
woolford's Avatar
woolford
i just got the dipstick tube and used my own dipper. i had a piece of pipe made up to replace the cat so it is just a straight 2.5" pipe with lambda hole in it.(for your sensor) i didnt need to change flexi it bolted straight up to my ss exhaust.. very very raspy.. but with that and and a k&n panel and bluefin with the boot fully stripped out my speedo showed 137. on my 2.0l When i took it out for a drive.
Old Dec 30, 2009 | 11:49 AM
matt24680's Avatar
matt24680
yeah so i am gona get the manifold gaskets flexipipe and cat for a st170 so all i need is st170 dipstick tube ,possibly st170 powersteeringpipe and extend my 1.8 lambda sensor??is this right?also is there a video of a st170 mani on a focus 1.8 as i dont want to do this modification and find out it sounds very raspy and doesnt sound nice
Old Dec 30, 2009 | 11:58 AM
woolford's Avatar
woolford
look on you tube.. might be one there
Old Dec 30, 2009 | 07:34 PM
hineho87's Avatar
hineho87
yea m8, IMO i wudnt bother with PS pipe from st170 as its jus waste of £90!!
I will try find the guide for u if ya give me ya email address.
There is prob some on youtube. I put one up of me hard revin on photobucket
There is this one and the the other two are the ones where you can jus see exhaust. The one of my car is b4 manifold. I defo isnt to loud and is a lot better for long distances. Its jus wen u put ur foot down it sound sweeter
Matt
Old Dec 30, 2009 | 09:11 PM
airzfocus's Avatar
airzfocus
Manifold
Gaskets
Oil dipstick tube
Matt
this is all you need, i got the set up on mine, sounds better as said, performance gains aint out of this world but i found it was better acceleration towards top end, i just cable tied my powersteering pipe outta way after bending it as much as i could from manifold, no probs ere!
Old Dec 31, 2009 | 09:07 AM
hineho87's Avatar
hineho87
+1 ^^^^
Wen i get round to it wil take a pic of where mine is. Jus to add i noticed the pic up is better when puttin ur foot down at low revs as well
jonfoc
16
Sep 11, 2018 05:35 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
cossirob
Sep 3, 2015 09:17 PM
