newbie with xr3
hellooo. been watching here for a while so i thought i would join up. i have an w reg xr3 carb model done lots of work so far to it but still lots to do
this is what it was like when i first got it
just a taster will post plenty of pics of what ive done so far later when i have time
cheers drew
cheers drew
thanks for the welcomes
i purchased this off fleabay. described as complete but needs a bit of welding.
i think if i had of welded it all in one go it would have taken me about three weeks. luckily i have a mate with his own garage and use of his welder.
took a while to reconstruct but im proud of this
n/s inner wing
the holes just keep coming
made the bits off a mk4 fit as money was tight and i couldnt afford new panels
im not the worlds best welder but im good at grinding
this o/s rear inner sill was a right pig to do
put interior back in
ive had to take the interior out recently as there is a leak into drivers side, i cant find where it is coming in yet though
repaired big dent in the wing
its looking more like xr3 now
there was a deep scratch to the rear panel but i noticed the rear panel i rippled so there is accident damage here
the roof also wants sorting so my mate is coming in the new year to give me a quote for a respray. so im still aquiring bits for it,i have 2 mint doors and tailgate in the garage to go on
so it got put on hold over summer as we bought my son a mini for his 18th birthday but that ended up needing more welding than the escort
cheers drew
n/s inner wing
cheers drew
here are a few of the roof it had a vinyl roof on before i got it which had been removed. its full of dents like someone has run over the top
i did sort it took ages
i didnt get chance to sort it properly due to the weather so this happened
found a few pics of my old car
cheers drew
cheers drew
thanks for the welcome mate . im ok for an interior mine came up ok after i cleaned it, but thanks for the offer
cheers drew
ive been busy this weekend while we had nice weather.Managed to fill, sand and respray my damaged roof.
after alot of wet and drying and alot of t cut im finally happy with it
took my side window out and sprayed in the mat black, but i marked it when i put the window back in so i will need to touch that bit up again
i also removed th screen so i could sort th scuttle panel
put all my interior back in after i found out where my leak was
this is where it was leaking it was very well filled by the last owner but i decided to be brutal with it and found it was just filler and sealant.
so overall im very happy with my results
cheers drew
cheers drew
been busy over the last few months
replaced rotten spare wheel well
my mate gave me this
im very happy with the results
struggled to my old rear my lamp out, when i did i found more holes to fix
[IMG]
now fixed
http://i930.photobucket.com/albums/a...910_161401.jpg[/IMG]
sorted my wheels, took me weeks to sort these
then got buried for winter
so recently got it running properly, fitted a new alternator, sorted the none existing brakes
now ready for an mot when i can afford
thanks drew
[IMG]
now fixed
thanks drew
MIbluEscos
Ford Escort RS Cosworth
Nov 28, 2004 11:18 PM
another good person keeping the MK3's on the road
