Turbo Sizes?????
Old Dec 10, 2009 | 06:52 PM
Billy_RS's Avatar
Billy_RS
Default Turbo Sizes?????
Got a really good condition Garrett T35 that im going to sell but i cant remember the sizes of it.
I dont know if its a t35.48 or .63 or ??
also how do you work out the AR and if its 360 bearing and all that goodness?
Cheers Billy
Old Dec 11, 2009 | 09:47 PM
Billy_RS's Avatar
Billy_RS
Old Dec 11, 2009 | 10:49 PM
mechanic28's Avatar
mechanic28
i thought a t35 is just what turbo technic called there t34.55?
Old Dec 12, 2009 | 06:26 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
correct doug all be it the TT T35 has a slightly higher flow compressor wheel and a 7 degree cut back on the exhaust wheel
If it is a genuine TT one it will have a tt id plate with serial numbers part numbers etc
Old Dec 12, 2009 | 07:56 AM
coswurv's Avatar
coswurv
Ive had a couple of these tt t35's and they all came with .55 exhaust housing's.
Old Dec 12, 2009 | 10:27 AM
VEEDUBBED's Avatar
VEEDUBBED
The A/R trim number is usually stamped inside the exhaust turbine housing,.63,.48,.82 etc.On the compressor side it's normally stamped near the outlet were the outlet hose connects or possibly just inside the neck,all T3/4's i've had and T4 turbos had these numbers cast there.Sometimes on the exhaust turbine housing the numbers are difficult to read due to rust and very small numbers.
Old Dec 12, 2009 | 11:46 AM
Billy_RS's Avatar
Billy_RS
Ok, cheers for that lads
Matt Baxter
Sep 16, 2015 08:30 PM
lee2cossies
Aug 26, 2015 10:04 PM
muz
Aug 16, 2015 12:57 PM
marky_g
Aug 3, 2015 04:45 PM
