Big Basterd in Kit Car :)
Old Dec 9, 2009 | 07:35 AM
BigNige's Avatar
BigNige
Default Big Basterd in Kit Car :)
Is it possible to do the following to a kit car
1. Extend the height of the roll bars by having an extra section welded on (proffesionally etc) and rough ideas of cost and who in the Herts/beds area
2. Extend a steering column to give greater knee clearance by cutting and sleeving then welding with a gash cut into each end of cut column does it impact the steerinig in a negative way
3, Take the sub frame of a cobra seat and bolt directly to floor i think this is easy and safe
Old Dec 9, 2009 | 07:44 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
I'm just trying to visualise Big Nige in a kit car.......
Size 10 bloke in a size 2 car.
Old Dec 9, 2009 | 07:56 AM
BigNige's Avatar
BigNige
Cock !!!!!!!!!!!!!!
Its a lugeo Viento big thing
so its a size 10bloke in a size 9 car hence the mods
Old Dec 9, 2009 | 07:58 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
Go on a diet instead you fat bastard.
Rich_bloor's Avatar
Rich_bloor
rich_bloor@hotmail.com
sounds interesting, im 6'6'' and have no way of getting in a kit car, unless it was a LWB
Old Dec 9, 2009 | 08:01 AM
BigNige's Avatar
BigNige
http://www.madabout-kitcars.com/pict...Cars_Viento+V8
There Huge inside
Chop when ebola gets you let me know i may show some sympathy till then FUCK YOU
Old Dec 9, 2009 | 08:07 AM
Christian and Beccy
#1 in Spelling Club
There Huge inside
Old Dec 9, 2009 | 08:14 AM
alistairolsen's Avatar
alistairolsen
Id source a taller hoop, have the existing one replaced completely rather han have welds part way up the uprights personally
Wouldn't impact the steering, but not the best solution. for a small amount, fit a spacer boss, for more, remount the column be redoing the brackets and extending the bar between column and rack.
is it side or base mount? Mounting with no subframe is fine, but Id want to be attaching it to lugs welded to the chassis rails rather than an alloy floor.
Old Dec 9, 2009 | 08:19 AM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
cheers big boy
x
Old Dec 9, 2009 | 08:29 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
Its a KIT CAR, so really anything is possible.
As long as its safe and more importantly looks "right" then its all good.
As for the roll cage, id personally remove it and make a complete new one to size, so it didnt look like an add-on. Tho I guess it depends how much you want to spend.
Im 6'4" so know how uncomfortable most cars are. Dont think ive found a car yet where everything is ergomomic the taller driver.
Old Dec 9, 2009 | 08:32 AM
BigNige's Avatar
BigNige
Originally Posted by Lambchop
cheers big boy
x
my pleasure x x x
Old Dec 9, 2009 | 09:45 AM
bj928's Avatar
bj928
you will get in a viento, i'm 6ft and 25 stone and i fit in mine, and steve xr4i is 6' 7" and he gets in it, not finnished yet but here is mine, it is a viento but has had a lot of extra strength put in to take the power.
Old Dec 9, 2009 | 09:57 AM
Big G's Avatar
Big G
Nige in kit car gives me the image of the average bloke in a supermarket trolley, It just dont look right
manuel boeckx
13
Oct 3, 2015 02:29 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
track.focus'd
Aug 12, 2015 05:53 PM
Blown Hell
Aug 5, 2015 07:22 AM
knight19770
Aug 4, 2015 12:36 PM
