Lifeline Fire Extinguishers GROUP BUY - We now have 10 :-)
We are now selling Lifeline Fire Extinguishers and we're setting up a Group Buy as a few of you on here and on the EscortRSCosworth Forum Board have expressed an interest
We need 10 definite orders for this to go ahead.
Group Buy prices (please note the information below and the prices have changed from the ones originally posted):-
We are also now offering highly discounted prices on services (which have to be done every 2 years) and refills to anyone who purchases a Lifeline Fire Extinguisher from us.
For example, a refill for the 101-225-001 Plumbed In Zero 2000 2.25ltr Club Fire Marshall Mechanical Kit will be £27.00 and a service will be £27.00 (including VAT).
ALL PRICES INCLUDE VAT
PLUMBED IN:
112-225-001 - Plumbed In Zero 2000 2.25ltr Club Fire Marshall Mechanical (Filled Bottle Only)
This is a superb entry-level Mechanical plumbed in extinguisher kit offering the same legendary quality as found in all Lifeline systems.
£77.00
OR
101-225-001 - Plumbed In Zero 2000 2.25ltr Club Fire Marshall Mechanical (Filled Bottle with Installation Kit)
Kit comes with:- 1 x 2.25ltr Club cylinder with bracket & straps; 2 x 6ft cable T handle c/w nipple; 2 x Discharge Nozzles; 4 x Meters semi rigid tube; 1 x Decal Pack; 1 x Instructions Manual.
126mm x 165mm x 510mm (incl. bracket & discharge heads).
£115.00
112-225-002 - Plumbed In Zero 2000 2.25ltr Fire Marshall Mechanical (Filled Bottle Only)
A high quality Mechanical plumbed in extinguisher kit with a hand crafted aluminium cylinder and aluminium mounting bracket.
£119.00
OR
101-225-002 - Plumbed In Zero 2000 2.25ltr Fire Marshall Mechanical (Filled Bottle with Installation Kit)
Kit comes with:- 1 x 2.25ltr Club cylinder with bracket & straps; 1 x 6ft cable T handle c/w nipple; 1 x 12ft cable T handle c/w nipple; 1 x T connector (push in); 2 x Discharge Nozzles; 4 x Meters semi rigid tube; 1 x Decal Pack; 1 x Instructions Manual.
165mm x 205mm x 300mm (incl. bracket & discharge heads).
£205.00
112-225-003 - Plumbed In Zero 2000 2.25ltr Fire Marshall Slimline Mechanical (Filled Bottle Only)
A slimline variant of the standard 2.25ltr Fire Marshal offering you greater flexibility when packaging the extinguisher into the confines of the modern competition vehicle.
£125.00
OR
101-225-003 - Plumbed In Zero 2000 2.25ltr Fire Marshall Slimline Mechanical (Filled Bottle with Installation Kit)
148mm x 188mm x 380mm (incl. bracket & discharge heads).
£220.00
HANDHELD:
201-100-001 - 1.0ltr AFFF (Foam) Hand Held Fire Extinguisher.
Portable fire extinguisher ideal for your road car, trailer, caravan or workshop.
This portable fire extinguisher is not approved for use in motorsport.
For use on class A, B and C fires including low voltage electrics.
Supplied complete with a bracket and quick release strap for easy access. All units have a 2 year servicing cycle.
Height = 331mm; Diameter = 90mm; Operating Pressure (Bar) = 12
£49.00
201-100-002 - 1.75ltr AFFF (Foam) Hand Held Fire Extinguisher.
Portable fire extinguisher for national rallying, sprints/hillclimbs or pre 31/12/60 historic racing.
Height = 375mm; Diameter = 100mm; Operating Pressure (Bar) = 12
£55.00
201-100-003 - 2.4ltr AFFF (Foam) Hand Held Fire Extinguisher.
Portable fire extinguisher for international rallying.
Height = 440mm; Diameter = 100mm; Operating Pressure (Bar) = 12
£66.50
201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher.
Portable fire extinguisher for international rallying but fitted with a flexible dip tube so it can be operated on its side or even upside down.
Height = 276mm; Diameter = 150mm; Operating Pressure (Bar) = 12
£105.00
201-100-005 - 2.4ltr AFFF (Foam) Slimline Hand Held Fire Extinguisher.
Slimline cylinder to allow greater flexibility when packaging within the confines of the modern competition vehicle with a flexible clip tube.
Height = 350mm; Diameter = 120mm; Operating Pressure (Bar) = 12
£105.00
PLEASE NOTE THE PRODUCTS ABOVE ARE JUST A SMALL RANGE FROM LIFELINE - IF YOU WOULD LIKE TO PURCHASE A DIFFERENT MODEL AS PART OF THIS GROUP BUY, LET US KNOW AND WE'LL UPDATE THIS LIST WITH THE DETAILS AND PRICES.
After reading many posts regarding underbonnet fires destroying people's pride and joy, I think it would be a good idea to promote car safety equipment as well as the normal go faster goodies as we have got a lot of money tied up in these cars
I know these products from Lifeline are more expensive than the 'Halfords' type extinguisher, but these are proper car extinguishers meant for oil and petrol fires and are also used in WRC cars.
I think the handheld range is good as then you can move it from car to car, use it in the garage or if you find somebody elses car on fire and feel like a good samaritan you could use it then also
. Or quite a few of you have expressed an interest in the plumbed in versions.
PLUMBED IN:
£77.00
OR
£115.00
£119.00
OR
£205.00
£125.00
OR
£220.00
HANDHELD:
£49.00
£55.00
£66.50
£105.00
£105.00
http://www.lifeline-fire.co.uk/downl...01-225-001.pdf
Looks like we should have enough interest to put together a Group Buy. We need 10 definites and then we'll get the orders sorted
.There are a few people interested on the EscortRSCosworth forum board too.
If you could confirm this is the model you are interested in, I'll work out some prices and update the post asap...
Have updated our website with a few more models...
http://www.rapidford.co.uk/shop/index.php?cPath=59_61&osCsid=696051aoffb4trj3mrcqp apdp0
Natalie
Rapid-Ford
The Group Buy price for the Plumbed In Zero 2000 2.25ltr Club Fire Marshall Mechanical (Bottle Only) is £77.00 plus £15.00 postage to UK Mainland.
If anyone else wants a different model, let us know and we'll confirm the price. Once we've got 10 orders the Group Buy can go ahead
dan can you confirm that it's not just the bottle as that kit comes with all the pipes cables etc
and if I order 2 (or maybe 3) will the postage be £30 or reduced accordingly?
steve
steve
The postage will be reduced accordingly
So far the following people have said they want to participate in this Group Buy.
PLEASE COULD YOU LET ME KNOW IF YOU WANT TO ADD YOUR NAME TO IT AND THE MODEL YOU WANT TO BUY (SEE FIRST POST) - or please let me know if you want your name taken off this list (if you'd rather not participate in this group buy).
1) the youth (PassionFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical
2) righthooker (PassoinFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical
3) Alps Pacino (PassionFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical
4) WENNY (EscortRSCosworth)
5) Chopper1981 (EscortRSCosworth)
6) Ryan81 (EscortRSCosworth)
7) fordrallycar (EscortRSCosworth)
8) c20tbo (EscortRSCosworth)
9) JB Fletch (PassionFord)??
10) FletchCossie (PassionFord)??
Once we've got 10 definites, we'll start taking the orders and payments
Can anyone else confirm which model they want (or let us know if you want your name taken off the list)??
The Plumbed In Slimline model is a kit (comes with 1 x 2.25ltr Club cylinder with bracket & straps; 1 x 6ft cable T handle c/w nipple; 1 x 12ft cable T handle c/w nipple; 1 x T connector (push in); 2 x Discharge Nozzles; 4 x Meters semi rigid tube; 1 x Decal Pack; 1 x Instructions Manual)
1) the youth (PassionFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical (£77.00)
2) righthooker (PassoinFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical (£77.00)
3) Alps Pacino (PassionFord) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical (£77.00)
8) c20tbo (PassionFord) - 112-225-003 - Plumbed In Zero 2000 2.25ltr Fire Marshall Slimline Mechanical (£125.00)
4) c20tbo (PassionFord) - 112-225-003 - Plumbed In Zero 2000 2.25ltr Fire Marshall Slimline Mechanical (£125.00)
5) Roosie (EscortRSCosworth) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical (£77.00)
5 more to go...
WENNY (EscortRSCosworth)??
Chopper1981 (EscortRSCosworth)??
Ryan81 (EscortRSCosworth)??
fordrallycar (EscortRSCosworth)??
5 more to go...
£55.00
will have that matey.will get in touch with Ryan81 and see if we can have combined postage to jersey.cheeRS
£55.00
6) fezzajsy (PassionFord) - 201-100-002 - 1.75ltr AFFF (Foam) Hand Held Fire Extinguisher (£55.00)
4 more to go...
4 more to go...
7) WENNY (EscortRSCosworth) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical (£77.00)
8) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher (£105.00)
9) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher (£105.00)
1 more to go...
Ryan81 (EscortRSCosworth)?? (possibly combined postage with fezzajsy)??
1 more to go...
WOOPS
. Really sorry - but have realised I've got the information wrong on the Plumbed In extinguishers (Natalie writing I must add - not Daniel)!!! -
I HAVE UPDATED THE INFORMATION AND PRICES ON THE FIRST POST NOW, SO IF YOUR NAME IS HIGHLIGHTED IN RED BELOW - PLEASE COULD YOU CHECK THE UPDATED INFO AND PRICES AND CONFIRM WHICH VERSION YOU WANT (OR IF YOU WANT TO PULL OUT OF THE GROUP BUY).
Really sorry again for my error
4) c20tbo (PassionFord) - 112-225-003 - Zero 2000 2.25ltr Fire Marshall Slimline Mechanical
as clive has said, there must be some mistake as the clubman kit is exactly that a kit!!
see here
http://www.rallydesign.co.uk/product...r4hg59escbbpc0
steve
see here
steve
see here
steve
see here
steve
Basically - I don't know how Rally Design are offering that kit at that price (don't forget their price is plus 17.5% VAT in the new year). We would be making a loss if we matched it, so obviously can't do that
Don't know if it makes any difference, but not all companies can offer telephone support and customer service up to 10pm 7 days a week (and often later on here!), so it is not just the prices you should look at
Anyway - please could you let us know if you want to take your names off the list (or if you want to leave it on) and hopefully we'll still get 10 orders together so this can still go ahead.
1) c20tbo (PassionFord) - 112-225-003 - Zero 2000 2.25ltr Fire Marshall Slimline Mechanical Kit (£220.00) CONFIRMED
2) fezzajsy (PassionFord) - 201-100-002 - 1.75ltr AFFF (Foam) Hand Held Fire Extinguisher (£55.00) CONFIRMED
3) WENNY (EscortRSCosworth) - 112-225-001 Zero 2000 2.25ltr Club Fire Marshall Mechanical
4) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher (£105.00) CONFIRMED
5) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher (£105.00) CONFIRMED
Only 5 or 6 more needed...
1) c20tbo (PassionFord) - 112-225-003 - Zero 2000 2.25ltr Fire Marshall Slimline Mechanical Kit CONFIRMED
2) fezzajsy (PassionFord) - 201-100-002 - 1.75ltr AFFF (Foam) Hand Held Fire Extinguisher CONFIRMED
4) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher CONFIRMED
5) Mark RS (EscortRSCosworth) - 201-100-004 - 2.4ltr AFFF (Foam) Dumpy Hand Held Fire Extinguisher CONFIRMED
6) Georgie1 (EscortRSCosworth) - 101-225-002 - Plumbed In Zero 2000 2.25ltr Fire Marshall Mechanical (Filled Bottle with Installation Kit) CONFIRMED
Only 4 or 5 more needed...
WENNY - did you still want one????
so is this kit
£115.00
the same as this
£115.00
the same as this
Yes it is, but their price is plus VAT and we are offering highly discounted prices on services (which have to be done every 2 years) and refills to anyone who purchases a Lifeline Fire Extinguisher from us.
