rs turbo smokes a lot when cold what does it sound like pls
Old Dec 31, 2004 | 09:41 AM
jaiscossie's Avatar
jaiscossie
Default rs turbo smokes a lot when cold what does it sound like pls
hi had my series two turbo for a couple of months now , on my 3rd one !!
if the car is left over night i start it up , drive up the road then after 2mins it starts to pour out blue smoke ,it does it for about 2 minutes then calms down.
it also does it if you boot it when warm when you let off the throttle.
ppl had said it could be various things just wanted some ppls advice as you may of been asked this before
it is definatly oil as there is an oily resadue round the exhaust and even spots on the bumper
shame cos the bodywork on this car is lovely and only had two previous owners so really would like to get it sorted
many thanks in advance and a happy new year to you all
Old Dec 31, 2004 | 12:28 PM
GrimmeRS2K's Avatar
GrimmeRS2K
could be the turbo mate, or worn rings.
Old Dec 31, 2004 | 06:46 PM
sammy's Avatar
sammy
i would check all the breather pipes & gallerys are clear to start with & make sure its not over full of oil (though its probably not), if all ok check inside the charge carrier for excess oil deposits if there is, its prob turbo, if not, rings.
Old Dec 31, 2004 | 10:12 PM
PAULDOLMAN's Avatar
PAULDOLMAN
i'd agree mate, before doing anything to drastic chack and clean all the pipes surrounding the oil breather i had the same problem with mine and that's what it was
Old Jan 1, 2005 | 12:02 PM
Red16's Avatar
Red16
normally smoke on a cold start up means the valve stem seals are worn
if the rings were worn i'd imagin it'd smoke constantly, larger amount of smoke depending on the more badly worn they are.
i had a problem with my old frst, only smoked if it came on boost then you backed off the throttle, would get a cloud of smoke out the back, oil seal in the turbo was goosed, new turbo on it and problem went away
Matt Baxter
Sep 16, 2015 08:30 PM
The Enigma
13
Aug 20, 2015 09:38 PM
muz
Aug 16, 2015 12:57 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
Adam-M
22
Aug 10, 2015 10:46 AM
