External Wastegate
Old Mar 8, 2004 | 10:43 PM
Default External Wastegate
Can anyone tell me what the pro's And Conns are of converting my 2wd Cossie to take an External Wastegate as ive noticed all the germans an fin's seem to be going down this road
Old Mar 18, 2004 | 07:19 PM
AustenW's Avatar
AustenW
Better holding of boost, greater power potential as more gasses can escape quickly through the larger hole etc. etc.
You have to spend alot on a decent external actuator though as the stems can bend due to the high amounts of heat. Once bent they will not seat properly which will increase your lag as the turbo will not spin up as fast due to the leak.
Stick to normal type actuator unless you want to spend £15k+ on a 600bhp+ motor
May 31, 2016 09:28 PM
pabloXR
Sep 21, 2015 12:42 PM
coscor86
Sep 20, 2015 01:21 PM
RSBryden
Sep 6, 2015 08:39 PM
Aug 14, 2015 07:29 AM
