4x4 cos no spark
Old Dec 30, 2004 | 09:03 PM
2ndGear's Avatar
2ndGear
Default 4x4 cos no spark
No spark on my cossie, coil gets very hot, crank sensor ok. any hellp?
Old Dec 30, 2004 | 09:16 PM
Alvyn's Avatar
Alvyn
have u tried a different ignition amp it's bolted on the inner wing.
Old Dec 30, 2004 | 09:30 PM
RS500/364's Avatar
RS500/364
Had some thing like this ECU was the fault
Old Jan 3, 2005 | 03:02 PM
mmsport's Avatar
mmsport
r u getting a spark from the coil when u turn your ignition 2 position 2? if u r, u can forget your ignition amp and crank sensor. it's more than likely 2 be your rotor arm or phase sensor in your dissy. hopes this helps mate.
Old Jan 3, 2005 | 06:24 PM
2ndGear's Avatar
2ndGear
not getting a spark when on position 2 ignition. Have bought crank sensor and fitted it no different. Looks like ignition amp or ECU?
Old Jan 3, 2005 | 08:33 PM
Dean Saff's Avatar
Dean Saff
Use a test light and see if it flashes @ the coil switching wire, if it does then it's the coil. if it dont then my money is on the ignition amplifer.
Old Jan 4, 2005 | 02:16 PM
2ndGear's Avatar
2ndGear
Default still no spark
tried new ignition amp and crank sensor, exactly the same!!!
Anyone else had this????
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
deathrider666
Sep 28, 2015 06:12 PM
